| Chassis & Suspension General chassis and suspension questions |
Thread Tools | Rate Thread | Display Modes |
#1 |
Registered User
Frame swap?
I have a 65 C10 2wd and am looking to swap to a 4wd frame. I found a 1983 K20 suburban donor but unsure of total length of it. The info I found said the wheelbases were almost the same and I know I'll have to fabricate the mounts. What do you think? Also I went to go rent a tractor on a trailer and the guy told me I needed at least a 3/4 ton to pull it (that's why I found the K20). What's the difference between 1/2 and 3/4 and is it really necessary to go bigger? You guys are great! Thanks, Matt.
#2 |
Registered User
sorry i have no info but im considering the same thing let us know what you find out about the swap as for 3/4 vs 1/2 i know for a fact my 3/4 has a much beafier drivetrain from the motor back
__________________
#3 |
Registered User
Frame swap
I have joshes factory dropped sub frame and it is 2 inches lower
it is really a nice set up. Team kawi also has a dropped set of nerfs. we cant buy them.
__________________
run engine on water |
#4 | |
Charter Member
Quote:
don't think you will have much luck trying to get an 83 frame under a 65 truck. The rear kick-up is completly different. Getting the radiator core support to fit so that all the fenders, hood, etc etc, will line up properly would also be very difficult. dv
__________________
1964 C10 Panel 350 HO Crate and 700R4 1937 Ford Cabriolet ZZ4 & Tremic 5 speed |
#5 |
Registered User
73-87 1/2 ton and 3/4 frame are the same, only one ton is bigger. the rear spring length is 52" on 1/2 and 3/4 ton unless vehicle was optioned with C6P heavy duty chassis 8600 GVW. In that case you got 56" long rear springs, otherwise chassis still the same. You can see both sets of holes on any chassis. 1/2 ton and 3/4 ton have the same front end except 6 lug or 8 lug hubs, rotors, calipers and brackets. 1/2 and 3/4 ton used same transfer cases depedent on transmission option.
| Thread Tools | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 55-57 frame swap | racerdon | Chassis & Suspension | 1 | 07-03-2008 02:56 AM |
| Frame swap | 66pickup | 1960-1966 | 6 | 04-10-2008 07:50 PM |
| frame swap question | wschmpn | 1947-1954 | 11 | 12-15-2007 06:05 PM |
| 1954/S10 frame swap | aasmitty757 | General Chevy & GMC Pickups Talk | 3 | 09-13-2006 11:54 PM |
| 59 fleetside frame swap | austinjn | 1955-1959 | 4 | 10-10-2005 05:42 PM |
