very nice,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, since you live up there you know, dan m. who lives up rawhide, he's a racer
Hey big Tim can we get a good look at that motor in your profile pic is that what I think it is ?
Why yes , yes it is and thanks for noticing......It's a
261 Chevy .030 over with 9.5-1 Jans pistons .125 shaved off the head with resesed valves, porting and .08 decked off the top of the block with head studs installed. The center weight was chopped of the crank and the crank was balanced Custom 4 bolt main caps were made and the rods were shot peen and I beam ground with ARP rod bolts installed. A custom Crowler cam shaft was made and Clifford made an Alum. fly wheel. A custom tunnel ram was made by me as well as a set of S.S. fender well headers. Two Holly 350 CFM Carbs with 50 CC accelerator pumps, Mallory (YC) type distributor, Mallory coil, and Accel 8.8 mm wires were used with an MSD 6A ignition box with timing control. Borg Warner super T 10 4 SPD. with a vertical gate shifter, narrowed 9 In., Strange billet carrier, Detroit Locker with 456 gears. All machine work was done by Bell & Gains Service and assembled by Larry Neville of Neville Bros. Automotive Modesto Ca. and myself This thing will smoke them 31x18.50x15 Micky's through 2 gears, rip 3Rd. and bark 4TH OH YEAH...
View attachment 5281[/QUOTE]
