How to identify rear axle?
Discussion in 'Chassis & Suspension' started by 91northbound, Sep 15, 2007.
  1. 91northbound
    91northbound Member
    Hello, first timer here. I bought a '58 apache which doesn't have the original drive train. I was wondering how I could identify the rear axle.
    It is a 10 bolt and it has 5 wheel studs. there a 2 diagonal brackets
    with rubber bushings on top of the differential case (maybe for stabilizer
    bars?) and it is about 59 inches from between backing plates. Is there
    any way to tell what it is?
  2. truck_oldschool
    truck_oldschool Member
    look up the bolt pattern at a auto store, or look for a number tag casting numbers, but it sounds like it could be one off a 72 or newer axle. hope that helps
  3. drabo
    drabo Member
    Patrick AFB, Florida
  4. kkuenemann
    kkuenemann Member
    Longview, TX
    Are the brackets part of the casting? If so, it is most likely a 10 bolt out of a Chevelle, Monte Carlo or similar GM car. Those where for the upper factory 4 link bars.
