power steering mounts for 216, 235 & 261
Discussion in 'Truck Parts for Sale' started by drummin52, Jul 8, 2009.
  1. drummin52
    drummin52 Member
    Wapwallopen, Pa
    power steering pump mounts for 216, 235 & 261 inline 6's
    UPDATED AD - 07/27/2016
    2 bracket sets available for
    216 and early 235 inline 6
    Late 235 and 261 inline 6 with or without motor mount
    Both sets locate the power steering pump in the original location of the generator/alternator. The alternator is then positioned above the power steering pump. A power steering pump with a dual groove power steering pump pulley is required as well as 2 belts. The first belt, driven by the crank pulley drives both the p/s pump and water pump/cooling fan. The second belt drives the alternator using the second groove on the p/s pump pulley. A dual groove crank shaft pulley is NOT required. This kit should work however, with a dual groove crank pulley setup. It is unknown/untried whether this kit will work with a generator instead of a alternator as I have never seen if it would fit.
    216 and Early 235
    http://i175.photobucket.com/albums/w124/rockfan1815/brackets for sale/102_1040.jpg
    Late 235 and 261
    Photo by Chris Drum
    Both sets will come with the following
    - Power steering pump bracket w/ mounting hardware
    - Alternator bracket w/ mounting hardware and 2 head bolt studs (which are required in order to mount the bracket)
    - Belt adjuster brackets for both the alternator and p/s pump w/ mounting hardware
    The price for either set comes to $160 Shipped. This includes everything listed above. Total cost for those in Canada is $175 Shipped.
    If interested please email me at cdrum89 at yahoo dot com or call 570 233 1172
    Here are some pictures from other members that have purchased my bracket sets for their inline 6's.
    http://i175.photobucket.com/albums/w124/rockfan1815/brackets for sale/Untitled4.png
    http://i175.photobucket.com/albums/w124/rockfan1815/brackets for sale/Untitled3.png
    http://i175.photobucket.com/albums/w124/rockfan1815/brackets for sale/Untitled2.png
    http://i175.photobucket.com/albums/w124/rockfan1815/brackets for sale/Untitled1.png
    http://i175.photobucket.com/albums/w124/rockfan1815/brackets for sale/PA080751.jpg
    http://i175.photobucket.com/albums/w124/rockfan1815/brackets for sale/PA080748.jpg
    http://i175.photobucket.com/albums/w124/rockfan1815/brackets for sale/altsteeringmt453.jpg
    http://i175.photobucket.com/albums/w124/rockfan1815/brackets for sale/altsteeringmt451.jpg
    I have sold close to 70 sets since I started making these in 2009.
    **Edited 7/27/16 - Price increase due to material and shipping cost increase**
  2. drummin52
    drummin52 Member
    Wapwallopen, Pa
  3. drummin52
    drummin52 Member
    Wapwallopen, Pa
    just a bump to the top
    PM me for contact info.
  4. drummin52
    drummin52 Member
    Wapwallopen, Pa
    will also take trades for truck parts
    looking for front and side window glass for my 52. The side door glass has to be for the early years without the wing/vent windows. Also in need of a good tailgate (want one that requires no major work), bed wood, headlight buckets, rear bumper and brackets or a roll pan, 3/4 ton running boards. Let me know what you have.
    Thanks
  5. RobY56
    RobY56 Member
    San Diego, CA
    Voltage output question
    What kind of DC Voltage is your alternator putting out, with that set-up you created? Above 13VDC? Mine is similar but you have it down clean.
  6. drummin52
    drummin52 Member
    Wapwallopen, Pa
    Voltmeter is right around 14-15volts.
    I am still selling these brackets if anyone is interested.
    FREE SHIPPING $140 SHIPPED!!!
  7. bowtiesr4me
    bowtiesr4me Member
    Evington VA. USA
    brackets
    Hey Chris,
    tried your e-mail address but would not work so I'll ask u here. Do u make brackets for 327 sbc w/double hump heads?
    If so I need them for Alt, PS and AIR.
    Please send pics and prices if available.
    Thanx!
    Mike
  8. drummin52
    drummin52 Member
    Wapwallopen, Pa
    sorry just the inline motors.
  9. drummin52
    drummin52 Member
    Wapwallopen, Pa
    I have 1 set for the 216/early 235 and 2 sets for the later 235/261 left. After these are gone, I'm done making more for a while as I have college classes in the morning and work in the afternoon/evening which only leaves the weekend for free time and my truck is calling my name.
    When these 3 are gone, if you would like a set I would be more than happy to send you the drawings and some instructions on how they go together. I use this place to cut out the parts.
    There was a person that copied my design and was selling them on ebay for a bit more than I was asking (without head bolts, hardware and belt adjusters) but I couldn't find the listing again.
  10. drummin52
    drummin52 Member
    Wapwallopen, Pa
    I have 1 set for the 216/Early 235 and 1 set for the Late 235/261 left. I just sent in my order to have a few more sets cut out and should receive the parts mid next week.
    I made a few slight changes in my designs to make it easier for me to assemble and weld the pieces together, should help with accuracy when lining the pieces up and also for a cleaner look.
    I also designed another bracket for the Late 235/261's that have the front driverside motor mount direcly below where the stock generator/alternator mounts. This was recently brought to my attention by a customer I sold a set to. Working with him I designed a new bracket and had it shipped as fast as possible to him.
    Another thing that was brought to my attention is that on some inlines the first head bolt on the drivers side (towards the radiator) is .200" inward then the rest of the head bolts. I made this change as well.
    If interested please PM me for contact info.
    I accept PayPal, money orders & checks. When using PayPal please use the Personal Tab and select Payment Owed. I do this on the side, not as a business.
  11. drummin52
    drummin52 Member
    Wapwallopen, Pa
  12. drummin52
    drummin52 Member
    Wapwallopen, Pa
    Bump
    I have a few sets available. $160 Shipped ($175 for Canada)!!!!
  13. drummin52
    drummin52 Member
    Wapwallopen, Pa
    Bump to the top.
  14. drummin52
    drummin52 Member
    Wapwallopen, Pa
    Brackets still available!
  15. drummin52
    drummin52 Member
    Wapwallopen, Pa
    $160 Shipped!!!! $175 for Canada
  16. drummin52
    drummin52 Member
    Wapwallopen, Pa
    I have 2 bracket sets for a late 235/261 left. 1 set works for motors that use the front driverside engine mount and the other set is for motors that use the front mount (no engine mount on side of block).
    After these are gone, I will need to get more cut out. 2-3 week lead time.
  17. drummin52
    drummin52 Member
    Wapwallopen, Pa
    $160 shipped! $175 Canada
  18. drummin52
    drummin52 Member
    Wapwallopen, Pa
    I just sent my order to the local machine shop to have 6 sets cut out. Lead time is 2 weeks. About another week or 2 for me to get all the brackets welded together, etc.
  19. jackrabbitjoe
    jackrabbitjoe Member
    Interested in the steering pump mounts for a 235 please contact me by email josephgraves@cox.net
  20. Str8six
    Str8six Member
    Summerland BC Canada
    Belt adjuster pics?
    Hello Chris, I was searching the web for PS brackets for my '62 261 in my Canadian Pontiac wagon and came across your posts. Your brackets look great. Do you have a better pic of the adjusters mounted on the motor? I have an Offy tri-power intake that will be going on the motor once the rebuild is complete and am wondering if that upper Alt bracket will work with my setup. Cannot tell for sure from pics. What do you think? Thanks in advance.
    Steve
