Power Brake Setups?
Discussion in '1960-1966' started by grayhitandmiss, Mar 14, 2004.
  1. grayhitandmiss
    grayhitandmiss Member
    Have drum brakes on the front and rear of my 64 Chevy 1/2 ton.
    I want to purchase a power booster brake set up, but just as soon buy the disc / drum master cylinder/ booster setup, in case I decide to upgrade to front disc brakes.... if this setup will work on my all drum brake truck. I talked to the folks at #####.com, and they say their disc / drum booster will work. All I have to do is remove the proportional valve. Otherwise they say that the disc / drum setup has a bigger reservoir than their drum / drum booster setup.
    Does anyone know if I'm going to have any problems, ie., stopping, if I use a disc / drum setup, on my drum / drum truck?
    Have see this at online regarding a residual valve
    that makes me wonder if things will work out!
    http://www.mpbrakes.com/mpfaqmasters.htm
    A drum brake master will differ from a disc brake master in two ways. The amount of fluid that a drum brake master has to move is less than disc brake. Drum brake masters have 10 lb residual valves at the outlet to keep a residual pressure on the drums. If you use a drum brake master for disc brakes you would move an insufficient volume of fluid and the disc brakes would drag because of the residual valves.
    Any help much appreciated,
    Thanks, Tom
