Kent Moore and Miller Factory and Dealer Tools
Discussion in 'Truck Parts for Sale' started by GonicGM, Feb 14, 2009.
  1. GonicGM
    GonicGM Member
    Seacoast New Hampshire
    I have over 1000 line items of factory and dealership specialty service tools, most of which are for sale, new and used, old and new vehicles. These are the tools that are illustrated and itemized in your factory vehicle service manual. I have both SPX Kent-Moore and Miller service tools available for sale, some OTC Rotunda. Likewise, I purchase tools by the piece or lot.
  2. Greg_H
    Greg_H Member
    sent you a pm
  3. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    That a nice avitor pic, is that your truck. Maybe you can show some bigger pic's if it is. Good to know all can get some tool like in the factory vehicle service manual.
  4. trannybrad
    trannybrad Member
    looking for kent moore tool
    I am looking for the Kent Moore retaining ring pliers used on the 6L50/80/90 transmissions. Any chance you have these?
    Thanks,
    Brad
  5. GonicGM
    GonicGM Member
    Probably not. Do you have the KM number?
  6. GonicGM
    GonicGM Member
    It is and thank you. It is still currently a work in progress. I hope to have on road this summer. I'll try to get some images up. It is a 1983 K2500 GMC.. Originally a 6.2, now 350M. When finished, will have 350M, TH700R4, 4.10 Gears with 14 Bolt FF rear with Eaton posi, 10 bolt 8.5 front with Hummer Gleason diff ( similar to TrueTrac or Zexel ), Sierra Classic trim Blue, dual 20 gallon tanks, cargo lamp, cruise control, 8' Fisher Plow. Prior to reformulated gas could get 15.5 MPG highway with 4.10 and overdrive. Truck is C6P chassis, 8600 GVW, emissions exempt. Another unique thing is the 700R4 and controls. The 8600 GVW has no catalytic converter or computer. Converter lockup is all with vacuum switch, inline switch for 4th gear lockup, 4th to 3rd downshift unlock switch and brake switch. Simple two wire circuit to lockup solenoid. GM did this for only 82 83 84 on 8600 GVW trucks.
  7. Bill Hanlon
    I could use a KENT MOORE J-5071
  8. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Tools
    Would you have any of these items: J-553, J-1451, and J-1436?
  9. drk777
    drk777 Member
    Need Kent Moore tools for 4L30E
    What tools do you have available for the GM 4L30E transmission.
    Thanks,
    David
  10. GonicGM
    GonicGM Member
    The extent of my KM trans tools for sale is as follows:
    J-5386 53-57 Driver, transmission front pump seal, Chevrolet, Powerglide
    J-8885 61-63 Remover, Bushing, Front Pump Body
    J-8886-1 61-63 Installer, Bushing, Turbine Shaft, Tempest
    J-8898 61-63 Installer, Pinion Bearing Retainer Cup, Rear, Tempest
    J-9546 62-63 R&I, Bushing, Clutch Drum
    J-21249 61-63 Installer, Bearing, Needle, TempestTorque
    J-21709 R&I, Cap, Shift Lever Lock, Opel Kadett
    J-21714 Tool, Alignment, Clutch, Opel Kadett
    J-23082-01 Tool, Alignment, Torque Converter Housing to Pump, 3L30
    J-24547 T Arbor, Clutch Alignment, Luv, Isuzu, T-car
    J-24745 Tool, Loading, Cluster Gear, NP203 Transfer Case
    J-25022 Adapter,Fixture,End Play,Converter,245 mm,4L60/4L60E,700R4,200R4
    J-26935-3 Selector, Shim, 4 Speed Manual Transaxle, FX125, FX170
    J-26935-4 Selector, Shim, 4 Speed Manual Transaxle, FX125, FX170
    J-26935-13 Selector, Shim, 4 Speed Manual Transaxle, FX125, FX170
    J-26936 Installer,Seal and Bearing Cup,4 Spd Man Transaxle, FX125,FX170
    J-26942 Installer, Bearing Race, Input and Output Shaft, 4 SPD Man T/A
    J-26958-10A Plug, Adapter, 125THM4T60E,4T65E,
    J-28449 T Clutch Adjusting Gauge
    J-29041 Spanner, Mainshaft and Rear Extension Shaft, Luv
    J-29182 S Installer, bearing cup, pinion shaft, Geo Prizm Nova 3 Speed auto
    J-29793 Alignment tool, Countershaft, 4 Speed Manual, 89 mm Overdrive
    J-33008 Remover, Axle Shaft, Transaxle, 3T40(125 & 125C)
    J-33169 T, S, F Arbor, Clutch Alignment, 4 speed 1.5 1.9 2.2 Diesel, T series, S F
    J-33366 Fixture, Holding, Transaxle, 76mm 5-spd. (Isuzu M200)
    J-33370 R&I, Race, Bearing, Output Shaft, Rear, 5 Speed, 76mm, Isuzu M200
    J-33382 Gauge, Pin, Band Apply, 4T60, 4T60E, First, Second, Reverse
    J-33411 Installer, Gear, Bearing, Sleeve, Automatic Transaxle
    J-35425 Installer, Bearing and Seal, Rack & Pinion, M/TA, M/T
    J-35495-1 M,S Adapter Puller, Oil Pump, A/TA, S-Car 3 & 4 Speed
    J-35656 Installer, Bearing, Input Shaft, Front, 5 Speed, Nova
    J-35757 Arbor, clutch Alignment, Nova
    J-36506 R&R,Bush,5th & Rev Detent,5Spd Man Trans,5LM60(HM 290),NVG 3500,5TM40
    J-36507 R&R,Bush,Detent,Shift Shaft,5Spd Man Trans,5LM60(HM 290),NVG 3500,5TM40
    J-36509 Remover, Plug, Detent Spring,5Spd Man Trans,5LM60(HM 290),NVG 3500,5TM40
    J-36510 Install,Pivot,Clutch,5Spd Man Trans,5LM60(HM 290),NVG 3500,5TM40
    J-36516 Wrench,Spanner Nut,Output Shaft,5Spd Man Trans,5LM60(HM 290),NVG 3500,5TM40
    J-36549 Side bearing installer, Lemans, F-13 F-16 5 Speed
    J-36554 Retainer, Clutch Assembly, 5 Spd. Transaxle, F-13/F-16
    J-36799 Tool,Adj,End Play,Cshaft,5Spd Man Trans,5LM60(HM 290),NVG 3500,5TM40
    J-36824 Adapt,Fixt,Trans Hold,5Spd Man Trans,5LM60(HM 290),NVG 3500,5TM40
    J-36825 Remove,Seal,Output Shaft,5Spd Man Trans,5LM60(HM 290),NVG 3500,5TM40
    J-37158 Remover, Bearing, Inner, Clutch Shaft, Manual Trans. Sprint, Metro
    J-38288 Remover, Bearing, A/TA, Geo Storm, JF403E
    J-38296 Remover, Bearing, Reduction Gear, JF403E Automatic Transaxle
    J-38297-1 Remover, Idler Gear, 4 speed, Geo Storm
    J-38298 Compressor, Brake Spring, JF403E Automatic Transaxle
    J-41103-2 Remover, Seal, Torque Converter
    J-41103-8 Remover, Seal, Torque Converter
    J-41991 R&I, Driveshaft Bearing, 4T60E/4T65E
    J-44388 Set, Shim Selector, Getrag F23
    J-44755 Fixture, Holding, Transfer Case, Steyr, AWD
    J-45238 Installer, Needle Bearing, Input Gear, NVG 126/226
    J-45239 Installer, Needle Bearing, NVG 126/226
    J-45404 Tool, Alignment, Transmission Indicator, Equinox, Infinity/Nissan
  11. GonicGM
    GonicGM Member
    no good on J-5071, sorry.
  12. GonicGM
    GonicGM Member
    No good on those three either, sorry.
  13. mike bell
    mike bell Member
    Cadillac Band Adjusting tools Urgent
    Hi there I urgently need the band adjusting tools for the front and rear for my 1955 Cadillac with Hydramatic I believe they are kent moore J-5071 and either J-1693a or J-1803 can you help please I will pay all costs just need them thanks Mike Australia
  14. GonicGM
    GonicGM Member
    I don't have those. I posted a visitor message to your profile for contact info on someone that might.
  15. Keystoner
    Keystoner Member
    Pennsylvania
    Kent Moore J 8092
    Do you have J-8092
  16. GonicGM
    GonicGM Member
    I do. With your zip, I can quote total with shipping.
