I removed my fender (Drivers side Back) and had some rot on 2 holes were the fender attaches to the bed Panel. The 2 areas of rot I am talking about are right under the Bed Rail, so... Can I use some of that fiberglass pach on the underside of the bed panel and then a bit of bondo on the bed part of the panel, I know I will be plugging the holes were the 2 bolts go, and thought i could attach my new fender and then drill the 2 holes out and not Ratchet then down as tight as the other bolts that hold the fender on. My feeling is ..ther are enough bolts to keep the fender tight, and i sure do not want to buy a new bed panel..??? Anyone??? Mike G
