Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1960-1966
1960-1966 Discuss all aspects of your 1960-1966 Chevy or GMC Pickup
Reply
Old 04-22-2009, 08:12 PM   #1
64ChevyPickup
Registered User
Gas Tank Relocation?
I have a 64 c10 and I am wanting to relocate the gas tank to under the bed, and have seen the kits in classic parts, and car and truck shop for around 190 with sending unit, straps and etc. But to not have to pay for shipping and an oversize charge, I called my local classic muscle chevrolet dealer here in NC and they just have one for a 69-72, and I was wondering if this will work for mine or does anybody have other ideas that will work. I plan on lowering the truck so dont want anything to low. All ideas will be appreciated.
64ChevyPickup is offline   Reply With Quote
Old 04-24-2009, 09:40 AM   #2
LEYLAND
Registered User
LEYLAND's Avatar
69-72 should work but may need to modify filler neck or mounting straps... I'm also doing the tank swap now, using the larger blazer tank/sending unit.
two links to help you!
http://www.captkaoscustoms.com/blazertank.html
http://www.persh.org/pickup/TankBelow.htm
__________________
LEYLAND
65 C10, 350, 700R4
LEYLAND is offline   Reply With Quote
Old 04-27-2009, 09:33 PM   #3
66Squirt
Registered User
Tank nightmare
I have been dealng with this for over a month! I keep hearing about guys going to the blazer tank. The one thing I can tell you is DO NOT get the polyurathane one in the catalogs with the filler neck sticking out at a 45ยบ angle. I can't see how the aluminum one would be better either. What a giant pain in the butt! Try and get one sticking out of the top (straight up) or one directly out the side. If it's to late and you got that one a Nissan filler neck out of a old hard body is what I had to end up using. That and splice a couple hoses together to make it all work. I got my tank from Tuckers, LMC and Classic shows a picture looking exactly like what you do not want. I would definately ask more questions about the Blazer tank.
66Squirt is offline   Reply With Quote
Old 04-27-2009, 10:13 PM   #4
65Custom
Registered User
65Custom's Avatar
Gas Tank
I bought my tank from LMC it is and steel holds about 19 to 21 gallons I have fitted it and had to do very little fabrication to get it setup.
As for the filler I am planning a hidden filler where my bed floor will pop up and the filler cap will be there under the floor off to the Driver side I'm not a big fan of the fillers in the floor even though they look nice.
I just don't want spilled fuel on my nice finished wood floor, I was also planning to have the filler with a hose to drain any spillage out to the ground in case that happens so the filler support will be sorta of a catch and drain in the even of spillage
65Custom is offline   Reply With Quote
Old 04-28-2009, 01:00 PM   #5
64ChevyPickup
Registered User
thanks for the advice, I think I'm gonna get one of the kits from LMC or Truckshop, stopped by my local classic restoration and the one they sell for the 67-72 which the dimensions are the same so I figured it would work, but theres only comes with the tank no straps or anything and it was 150 so I think I'll just get the one like you did ( the kit)
Old 04-28-2009, 08:00 PM   #6
65Custom
Registered User
65Custom's Avatar
Gas Tank
Here is a pic the frame is upside down and the tank straps actually go front to rear, Sorry that I don't have a better picture with more detail or finished pics
Click image for larger version
Old 05-02-2009, 09:56 PM   #7
verdell
Registered User
For what its worth, both my brothers installed the blazer tanks in their '65 and '71 models with no major issues..however i decided on a factory 22 gallon '76 chevy van fuel tank in my '60...my rear frame is a little different and i didn't care for how low the blazer tank hung under the truck from the the rear view... mine is lowered about 5'" in the rear and i'm probably going with air springs. the van tank fits better and can barely be seen because it's not as deep as the blazer tank but with the same capacity...i'm real pleased with it..just my two cents!
verdell is offline   Reply With Quote
Old 05-03-2009, 08:35 AM   #8
HookedUpGTP
Registered User
HookedUpGTP's Avatar
verdell, how is your tank fill neck set up? I have a '61 and I'm looking to change out my under bed tank when I change out the wood the next time. I believe the '60 and '61 frame is the same frame.
__________________
'61 Chevy Fleetside Short Bed, 350, 700R-4, Power Steering, Power Barkes, Front Disc Brakes A/C
HookedUpGTP is offline   Reply With Quote
Old 05-04-2009, 05:33 PM   #9
Steven10
Registered User
Tank Filler
Dudes,
I do not want to put filler in my $1000, 30 hour install, week long varnished, white oak bed or fresh paint. Has anyone done a conversion that allows filling in some other place, short of punching hole in side of truck or in wood bed? What about inside fenders or licence plate? Thoughts?
Steven10 is offline   Reply With Quote
Old 05-04-2009, 08:49 PM   #10
HookedUpGTP
Registered User
That's why I asked about the fill neck set-up. When I replace the wood, I don't want a through the would fill either. I saw one truck (it may have been on Stovebolt.com), where the rear seal had a half circle cut out of it to accomodate the fill neck coming out just above the rear bumper. I would think that it'd be pretty easy to cut and hinge the license plate holder so that the plate could fold down as it used to do on a lot of cars.
__________________
Old 05-04-2009, 08:56 PM   #11
LEYLAND
Registered User
LEYLAND's Avatar
I saw one behind the rear lisence plate like the old buick, cutlass, cadillac's used to have but I believe it was a custom roll pan, not a bumper. (also saw a fella using a 60-66 front bumper on the rear (stepside truck) it looked WAY better than the bulky factory rear bumper) I also don't want mine coming through the bed floor or the rear fender so please post pictures when you figure something out....
__________________
LEYLAND
65 C10, 350, 700R4
Old 05-04-2009, 10:35 PM   #12
65Custom
Registered User
65Custom's Avatar
Filler Neck
I agree I don't want a hole in my nicely done floor
I saw one where the dude had the center board in the floor on hinges and then had the filler cap on the tank it was nicely hidden and no holes in the floor, the company that makes the kit is very expensive so I was going to fab something myself.
I was planning to have mine off to the drivers side behind the rear wheel where the board is short and put a filler cap off some newer car or truck but the door will be the wood board, the whole board will lift up to the right or left to expose the filler neck, nice and hidden
Old 05-05-2009, 05:54 AM   #13
verdell
Registered User
Currently, I'm simply filling thru my unfinished floor towards the driver's rear of the bed but plan to graft a "factory look" door fill from newer model car ( like my nissan maxima) into the rear of inner fender. I'm hoping to use an actuator or cable to unlock the fill door from inside the cab or some other place...actually saw the license plate fill door on a '64 but it won't work with my tank...just wanna try something different but don't want to fill from the bed floor or cut up those sexy bedside panels on my Apache!!
Old 05-06-2009, 12:03 PM   #14
dvalentine
Charter Member
dvalentine's Avatar
Cool
Quote:
FYI: The filler neck behind the lincense plate trick will not work very well..
The filler opening will be too low to fill the tank on our trucks. Also, as anyone who owned one of those cars so fitted with that filler neck will attest, even if you could get it to somehow work they are a royal pain in the keester to fill, requiring you to crouch down and keep your finger on the trigger because they shut off with annoying frequency !
The cleanest setup I've seen is the trick floorboard that flips up to expose the filler in the top of the tank. On fleetsides I've considered hiding the filler behing the taillight housing, like a 57 BelAir, but have not looked into the feasability of it from an engineering standpoint.
I did see one setup on a fleetside that used the area in the right rear steakbed hole, ( that were filled in ) , but it looked like a LOT of fabrication. It used one of those neat flip-up street rod gas doors seen on some rods...
dv
__________________
1964 C10 Panel 350 HO Crate and 700R4
1937 Ford Cabriolet ZZ4 & Tremic 5 speed
dvalentine is offline   Reply With Quote
Old 05-09-2009, 03:59 AM   #15
66 KUSTOM
Registered User
66 KUSTOM's Avatar
leave it ol skool like me, leave it behind the seat and smoke while driving with the gas fumes filling the cab!! you only live once!! i personall think the origanal gas filler sticking out of the side of the cab looks sick. plus it gives you a place to hang your shop rag.
__________________
66 KUSTOM
66 KUSTOM is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
