Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1960-1966
1960-1966 Discuss all aspects of your 1960-1966 Chevy or GMC Pickup
Reply
Old 01-02-2010, 09:40 PM   #1
johndringo
Registered User
power steering pump brackets - 283
Newbie here.
I'm in the process of installing power steering in my '62 using Chevy Duty's conversion kit. I'm using part off an '80 Cheyenne C10. The gear box is in but I'm debating where to install the power steering pump. The engine is a 283 that I was told was out of a 70's car (was in the pickup when I bought it). No AC but the alternator is on the top drivers side of the engine. Logical place looks to be near the bottom on the drivers side (near the gear box and plenty of room. I've got the brackets on on the pump from the '80. Am willing to fabricate the brackets if needed but am hoping for suggestions. Any thoughts would be appreciated.
johndringo is offline   Reply With Quote
Old 01-03-2010, 02:18 AM   #2
66 KUSTOM
Registered User
66 KUSTOM's Avatar
Im running a 350sb and mounted on the driver side, i believe most all of them are done that way, I suggest mounting on the driver side, keeps your lines shorter and easier to route.
__________________
66 KUSTOM
66 KUSTOM is offline   Reply With Quote
Old 01-03-2010, 02:29 PM   #3
markeb01
Registered User
markeb01's Avatar
I agree it should be low on the drivers side for all the reasons stated. You might want to look at the Alan Grove brackets if you're going to fabricate your own. They're flat steel and relatively simple in design. The P/S brackets are near the bottom of this link:
http://www.alangrovecomponents.com/S..._Long_Pump.htm
The following diagram shows a good layout of the parts:
http://www.alangrovecomponents.com/i...tions/402L.pdf
I'm curious what engine mounts you're using. Are you still running the horse shoe mount in the front, or side mounts? Mounting of the P/S brackets may be an interference problem with the horse shoe design.
markeb01 is offline   Reply With Quote
Old 01-13-2010, 07:47 PM   #4
bigtimjamestown
Registered User
bigtimjamestown's Avatar
Send a message via Yahoo to bigtimjamestown
Quote:
Originally Posted by johndringo View Post
Newbie here.
Try using a power steering pump and brackets from a 67-72 Chevy PU. w/short water pump. You will also need the duel shiv lower crank pulleys. You can also use the same pump and brackets from any 60s small block w/short water pump. Just try to make sure that everything comes from the same doner cause these parts tend to vary in design and will cause you trouble when you try to fit everything together.
bigtimjamestown is offline   Reply With Quote
Old 01-16-2010, 08:11 PM   #5
johndringo
Registered User
thanks
thanks for all the suggestions guys. Unfortunately for me, there wasn't an engine in the donor pickup and it's pretty evident that the engine had a long water pump. The good part is that the steering box is in. Waiting for the salvage yard to open on Monday to try to find my SBC SWP power steering bracket.
Old 02-26-2011, 02:09 AM   #6
petercarmon
Registered User
thanks for posting this as well. i'm in a similar situation, contemplating upgrading and installing power steering but i'm still a little shady on the how part. will watch out for tips.
________________________________
steering shaft
petercarmon is offline   Reply With Quote
Old 03-02-2011, 01:34 PM   #7
drabo
Registered User
drabo's Avatar
SWP and LWP use the same power steering bracket. Classic Industries sells factory repops.
__________________
66 Chevy C10 "The Nugget" 283/700R4
drabo is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
