Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1947-1954
1947-1954 Discuss all aspects of your 1947-1954 Chevy or GMC Pickup
Reply
Old 07-14-2010, 10:17 PM   #1
ol' chebby
Registered User
ol' chebby's Avatar
Send a message via AIM to ol' chebby
How to run new brake lines
If anyone is re doing their brake lines on a 1/2 ton short bed, you will need.....
1-20" line, from the master to a "t"
3 30" lines...1 from the "T" to the left front rubber line, 1 from the "T" accross the crossmember to another "T", and one from this "T" to the right front rubber line.
1 61" line from this "T" to the back,into...
1 union
1 40" line from union to rear rubber line.
With these lines, they fit exactly when bent, and you don't have to flare any fittings!
__________________
I'll paint anything that will stand still long enough!
WWW.rpettycustommurals.com
Advance Design Rescue...Bringin' 'em back, one body at a time.
ol' chebby is offline   Reply With Quote
Old 07-15-2010, 07:13 AM   #2
vwnate1
Registered User
vwnate1's Avatar
Thumbs up Great tip !
Thanx for sharing it .
One of these days I should prolly do this .
__________________
-Nate
' PASSION ' :
There are many things in life that will capture your eye , very few will capture your heart ~ those are the ones to persue .
Those are the ones worth keeping .
vwnate1 is offline   Reply With Quote
Old 07-16-2010, 11:56 AM   #3
Zig
Registered User
Zig's Avatar
Exclamation NOW you tell me...
I'll forgive you for being to late with this info for me if you post the same info for one of those "under cab" dual mc setups.
__________________
"Life is a highway, I wanna ride it all night long!"
Zig is online now   Reply With Quote
Old 07-16-2010, 02:29 PM   #4
ol' chebby
Registered User
ol' chebby's Avatar
For the dual M/C setups, I used a bracket from Master Power, a 67-76 corvette M/C for a disc/disc setup. I used 2 12" lines to the check valves(2# for disc, 10# for drums) then basically the same for the front, but ran the rear line down the driver's side to the "T" at the rear. I don't know exactly which sizes I used. NAPA now has a handy dandy kiosk with all their brake lines hanging out in the showroom. Grab at least 2 of each size, 3or4 30", 2 "T" blocks, 4 unions, then take back anything you don't need. Measure the general length of line needed, then use the lines that closest fit. Thread the system together, then come back and tighten everything when it is all layed out. A nice tubing bender is useful, but most can be bent by hand or knee if you are careful not to overbend or kink the lines.
__________________
Old 03-23-2013, 09:48 AM   #5
Zig
Registered User
Zig's Avatar
Thank you, Russ! This is just what I was looking for!
__________________
Old 03-24-2013, 02:52 PM   #6
ol' chebby
Registered User
ol' chebby's Avatar
Preset prop. valve...
http://www.mpbrakes.com/products/pro...product_id=614
adjustable prop. valve...
http://www.mpbrakes.com/products/pro...product_id=612
2psi residual....
http://www.mpbrakes.com/products/pro...product_id=616
10psi residual...
http://www.mpbrakes.com/products/pro...product_id=617
__________________
Old 03-24-2013, 03:42 PM   #7
Zig
Registered User
Zig's Avatar
Is a proportioning valve needed? Ouch with the price!
Thanks, though!
__________________
Old 03-25-2013, 03:23 AM   #8
Blueflame236
Registered User
Blueflame236's Avatar
Send a message via Skype™ to Blueflame236
Question Proportional valves choices and where to install ?
Thanks Russ for this information. When having stock brake lines in a combination front disc and rear drum brakes what would be technically adviceble to install the preset model or the adjustable one ? What is the difference between these to in function ?
N.B.I have seen power brake boosters units from CPP wich have the prop.valve unit directly installed underneath and connected to the booster !
But as this solution is a bit different as they are separated units , where would it be adviceble to instal the prop.valve ? I think maybe on the frame at the same level as the MC but i am not shore here ?
Never to old to learn new knowledge Thanks Martinius.
__________________
TAKE THE MONEY AND RUN
Blueflame236 is offline   Reply With Quote
Old 03-25-2013, 06:07 AM   #9
ol' chebby
Registered User
ol' chebby's Avatar
The preset prop valve is fine for most applications, mount right near the master. The adjustable is for those who like to fine tune or "fiddle" with things. Everyone I know sets them and forgets them.
There are cheaper versions of each product out there, these were just readily available as examples. Look at CPP, Speedway or Summit.
__________________
Old 03-25-2013, 07:19 AM   #10
Blueflame236
Registered User
Thumbs up The need of safety first !
To answer the question , yes it is in your combination of disc brakes and drums or disc brakes both in front and rear ! The prop.valve in general keeps the brake liguid pressure up and releases it in proportion where its needed towards the calipper . Russ allready explaned the rest earlyer. The MC without any prop. valve wont manage that as far as i know. Its not needed installing the prop valve with only drum drum aplications.
Martinius.
Quote:
Thanks, though!
__________________
Old 03-26-2013, 06:28 AM   #11
Blueflame236
Registered User
Question Dia brake lines ?
Russ
What is the outer and inner dia of the stock halv ton brake line?
When installing the lines between the dual mc and other parts will it be nescesary to have them expended at end of each line or do i stick the straight line into the holes of the mc connector without any modification ?
Martinius.
1 union
__________________
Old 03-26-2013, 11:02 AM   #12
Coach529
Registered User
Coach529's Avatar
Do I need the residual valves if I am using a prop valve?
__________________
1949 Chevy 3600
My Pictures!!
Coach529 is offline   Reply With Quote
Old 03-26-2013, 11:32 AM   #13
ol' chebby
Registered User
ol' chebby's Avatar
Yes, think of them as a check valve, they keep a specific pressure in the lines so you don't have flowback.
__________________
Old 03-26-2013, 01:11 PM   #14
Coach529
Registered User
Coach529's Avatar
Thanks Russ.
__________________
1949 Chevy 3600
My Pictures!!
Old 02-08-2014, 08:02 AM   #15
ol' chebby
Registered User
ol' chebby's Avatar
If using 4 wheel disc or 4 wheel drums, you don't need a proportioning valve. Only with a disc/drum setup do you need it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
