Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1947-1954
1947-1954 Discuss all aspects of your 1947-1954 Chevy or GMC Pickup
Reply
Old 09-28-2010, 06:01 PM   #1
penniwinkle
Registered User
penniwinkle's Avatar
Installing V8 into 1951 Chevy 1/2 ton
I've finally gotten around to mounting a Chevy 305 with a Turbo 400 attached. I have a new engine cross-member and a new cross-member for the tranny. Some quick measurements seem to indicate a space problem between the stock cross member (the cross member at the back of the engine compartment where the rear of the old 6 cyl was attached - might be called the 'bell housing cross member). This member is rivoted onto the side rails of the frame on my truck. The turbo 400 will possibly just fit between this cross member and the firewall but will be close. I have seen on some of the truck sites that this cross member is cut out. I'm hoping someone will have some suggestions on this...I'm somewhat reluctent to cut it. The new crossmember I ordered (for the motor and tranny) bolt in - not welded and would not want to depend on them to secure the rails. Any recommendations would be apprediated.
penniwinkle is offline   Reply With Quote
Old 09-28-2010, 06:57 PM   #2
bigtimjamestown
Registered User
bigtimjamestown's Avatar
Send a message via Yahoo to bigtimjamestown
Quote:
On all modern day vehicles they don't use a mid mount on the engine tranny combo. Just cut the original cross member out then set your engine and tranny in together. Set the engine where you want it then tak Weld or bolt your motor mounts into place. Then you use your tranny cross member to hold the back of the engine up. your frame will be plenty strong without that original cross member....Big Tim
__________________
bigtimjamestown is offline   Reply With Quote
Old 09-28-2010, 08:27 PM   #3
bowtiesr4me
Registered User
bowtiesr4me's Avatar
Thats the same way I installed mine.
I welded the motor mount and bolted
the tranny cross mount.
(easier to remove the trans. when problems happen)
Don't forget to angle your motor before welding the mounts solid.
Good luck,
Mike
bowtiesr4me is offline   Reply With Quote
Old 09-28-2010, 10:02 PM   #4
ol' chebby
Registered User
ol' chebby's Avatar
Send a message via AIM to ol' chebby
Cut it out. It is not necessary with the other cross members.
__________________
I'll paint anything that will stand still long enough!
WWW.rpettycustommurals.com
Advance Design Rescue...Bringin' 'em back, one body at a time.
ol' chebby is offline   Reply With Quote
Old 09-29-2010, 05:13 AM   #5
52wasp
Registered User
or even better....
Leave an inline 6 for Nate! Since the crossmember is riveted, if you have any uneasiness about "cutting it out", just drill/grind out the rivets, and remove it cleanly.
__________________
Mike
Wilton New Hampshire
52wasp is offline   Reply With Quote
Old 09-29-2010, 12:48 PM   #6
vwnate1
Registered User
vwnate1's Avatar
Thumbs up The RIGHT Way !
Is to hot up an InLine engine , they can easily be made to haul a$$ and the sound won't ever be mistaken for yet another (yawn) SBC) .
Just a thunk ya know , it's your truck so build it how you want .
__________________
-Nate
' PASSION ' :
There are many things in life that will capture your eye , very few will capture your heart ~ those are the ones to persue .
Those are the ones worth keeping .
vwnate1 is offline   Reply With Quote
Old 09-29-2010, 01:16 PM   #7
bigtimjamestown
Registered User
Did somebody say "the right way is to HOP UP a inliner"? I never get tired of this lol lol Click image for larger version
Name:	tims pics 025.jpg
ID:	6299 .......Big Tim
__________________
Old 09-30-2010, 11:20 AM   #8
vwnate1
Registered User
vwnate1's Avatar
Talking Guilty As Charged !
You and I both know it's easily done .
Few ever need the V-8 they so lust for .
__________________
-Nate
' PASSION ' :
Old 09-30-2010, 11:38 AM   #9
federale
Registered User
federale's Avatar
Re:V8
I did need the V8. When I bought the 53,she had a badly cracked block,I had an old Nova sitting around and one thing lead to another
__________________
Chevy Duty Charter Member
federale is offline   Reply With Quote
Old 09-30-2010, 09:06 PM   #10
willardgreen
Registered User
willardgreen's Avatar
Bet you Big Tim's 261 can smoke the 305, 327 & probably a 350. However the 6 aint cheap, nobody is willing to give away hand me down speed parts for the 6. The few, The proud, The expensive Inline 6s.
__________________
[/SIGPIC]Dummies like me don't have comprehensive coverage on their AD
willardgreen is offline   Reply With Quote
Old 10-01-2010, 04:31 AM   #11
bigtimjamestown
Registered User
Quote:
It's true my 261 does get up and run and I have embarrassed a few small blocks but my small block in my 61 is a whole lot faster....Big Tim Click image for larger version
__________________
Old 10-03-2010, 12:44 PM   #12
vwnate1
Registered User
vwnate1's Avatar
Talking Goddammitt Big Tim !
I'll say that '61 sure looks nice ! .
Out side _and_ under the hood .
__________________
-Nate
' PASSION ' :
Old 10-10-2010, 10:25 PM   #13
LaTroca52
Registered User
LaTroca52's Avatar
Talking v8 progress
Keep us posted on your progress Rodger
The 235 is in fired it up the other day sounds good waiting for the parts house to get a manifold gasket in small exhaust leak paint it put the sheet metal back on than get her back on the road again
Robert
LaTroca52 is offline   Reply With Quote
Old 10-20-2010, 02:41 PM   #14
penniwinkle
Registered User
v8 progress
Robert, glad to hear the 235 started and ran ok. She really ran good when I had it. Progress on the V8: Have cut out the crossmember, removed the rearend, have the new motor x-member ready as well as a tranny x-member but ran into a few issues. The brake lines were in the way of the new motor xmember and have had to 're plumb' all the lines. The rearend was fairly easy to remove but having some difficulty removing the e-brake cables (cannot reuse them on the new rearend I have - ther is a lot of rust and brackets don't want to let go). I fixed the leaking steering box and not sure if I will have to move it - I installed a set of 'block hugger' headers on the V8 and I installed the 'smaller' header on the driver's side. The steering box might just fit in the hole behind the header collector. I have also rewired the whole truck, installed new switches and bought aluminum 'guage inserts' for the dash (am going to use 2 1/16 guages and a 3 3/8 speedo - autometer). Am also installing a new floor shifter for the Turbo 400.
I hope to be finished by Christmas.
Roger
Old 10-20-2010, 02:47 PM   #15
penniwinkle
Registered User
v8 progress
By the way, the wife won't let me keep the old rearend in the back yard so I called Patricks (in Casa Grande) and he will take it off my hands (I hate to throw away parts). Guess I will give him back his ring and pinion gears (the 3.55) - guess I just rented them for a couple of years.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
