Classic Parts Talk
Go Back   Classic Parts Talk > General Truck Talk > Performance, Engine, and Transmission
Performance, Engine, and Transmission General performance modification, as well as engine and transmission questions.
Reply
Old 10-27-2010, 10:48 AM   #1
kieth
Registered User
Question 66 gmc swb fleetside 700r4 trans crossmember
I am thinking of reusing the original 3 spd bell housing crossmember as the rear crossmember for the new 350/ 700r4 transmission mount. I am using the engine mounts from the donor 91 suburban and the 3spd crossmember may be too low, as it looks now the engine and transmission are on a angle, should it be level ?
2. I have looked at using a aftermarket crossmember but they all look like they mount differently than my 700r4, they all show a center plate with 2 holes in. The 700r4 mounts with 2 bolts on the transmission with a molded rubber isolator that only has 1 bolt sticking down instead of the 2 in all the aftermarket crossmembers. Any one know why ? confused in Tulsa...
Thanks in advance for your help.......Kieth
kieth is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9 Beta 4
