Can someone help me diagnose the circuit for this turn signal controller? My signal lights work but the indicator light bulb in the controller does not flash. I have tested the bulb and it does work. How do I test for this problem? Thanks, Ernie
T.Sig. Indicator I had the older Signal Stat 900 series on my '49 and I had to run a tiny wire up to the switch and ground it's case .
Pilot Lamp FWIW ; When I did that , the green pilot lamp in the T.S. Switch , lit up all the time and flashed only when I used the signals . it didn't bother me...
