Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1960-1966
1960-1966 Discuss all aspects of your 1960-1966 Chevy or GMC Pickup
Reply
Old 08-16-2001, 11:06 AM   #1
bob39666
Registered User
Gas tank relocation
I have a 1966 chevrolet stepside short wheel base and was wondering if any one knew the easiest way to relocate the gas tank to under the bed. Will a gas tank from a 70 or 80 model truck work with a little modification. Also I was wondering if I remove my seat what would be the best to replace it with. What has worked the best for ya'll. thanks
bob39666 is offline   Reply With Quote
Old 08-20-2001, 02:29 PM   #2
brublack
Registered User
RE: Gas tank relocation
For relocating the gas tank, check out http://pages.zdnet.com/64moneypit/daves64chevy/id10.html as far as seats if you want new click on http://www.salesco.com/fullseats.htm or almost anything used in a full size pickup will work especially if you move your gas tank. I put a seat from an 80's Suburban in mine, just had to modify the original brackets a little. http://users.sisna.com/brublack/truck
brublack is offline   Reply With Quote
Old 11-19-2001, 06:43 PM   #3
monks 64 c10
Registered User
I have a freind that built a 69 c10 and he used a gas tank out of a 89 s10, also i just put a seat in my 64 c10 out of a 95 c1500, i went with the 40/20 split with the arm rest. The only adjustments were a few washers under the 40 side.
monks 64 c10 is offline   Reply With Quote
Old 11-19-2001, 07:36 PM   #4
speedball
Registered User
I removed my gas tank to the under side of my bed and am happy with the results. (safer too) I used a pre made tank from No Limit Engineering and it went in easily. I only had to move the rear cross member of the frame.
I used a Teas Design for my front seat and am happy with the fit and look although I had to make the seat bracket to bolt it to the floorboards.
Check my web page for details on both subjects and some pictures.
http://www.geocities.com/richmond2_99/64PU.html
http://talk.classicparts.com/images/...2_99/64PU.htmlhttp://talk.classicparts.com/images/...a05801775.html
speedball is offline   Reply With Quote
Old 01-26-2002, 03:48 AM   #5
1965_Hybrid
Registered User
Send a message via AIM to 1965_Hybrid
[updated:LAST EDITED ON Jan-26-02 AT 03:49 AM (CST)]What i've got planned for my truck is something along those lines. My '65 has probably a 17 gallon tank behind the seat. I'm going to remove that and place two saddle tanks under the bed tucked beneath the rear fenders. As cool as it maybe to tell everyone that your fuel tank is behind your seat it'll be safer to get it out of the cab.
Matt }>
__________________
Floor it or store it!
1965_Hybrid is offline   Reply With Quote
Old 01-26-2002, 08:31 AM   #6
Butch60stp
Registered User
Matt,
Are the saddle tanks under the rear fenders going to be inside or outside of the frame rails? Outside would be subject to explosions from side impacts like the 73 models wouldn't they?. I have thought about relocating my tank also, I don't like riding with an explosive
directly behind me.
Butch60stp
__________________
Butch60stp
Butch60stp is offline   Reply With Quote
Old 01-26-2002, 02:02 PM   #7
dvalentine
Charter Member
dvalentine's Avatar
If you go to the trouble of moving the tank out of the cab, ( a VERY good idea, by the way), move it between the frame rails. I've heard good and bad stories about the aftermarket tanks. Speedballs is a good one. A bad one is from a well know supplier named after a sibling. A friend installed their kit and it hung down lower than the rear differential and rear bumper. Not a very safe position for 20 gallons of potentially explosive material!
I have heard of folks using Jeep Cherokee tanks that fit well. I have a 64 Panel and the tank is already between the frame rails with a notch for the spare tire storage. (Don't hate me)
The seat? I picked up a 60/40 split bench out of a 70's C10. Fit like a glove including all mounting brackets. Warning ! Wrecking yards are asking a ton of American dollars for these. When I was looking, yards were quoting $500 to $700 for used seats that "needed" re doing. (!) I found mine from a vendor at a GoodGuys meet. It was already re done in tweed. He asked for $650, I offered $500 cash. Done deal.
__________________
1964 C10 Panel 350 HO Crate and 700R4
1937 Ford Cabriolet ZZ4 & Tremic 5 speed
dvalentine is offline   Reply With Quote
Old 01-27-2002, 01:14 AM   #8
1965_Hybrid
Registered User
Well, I smoke so it's kind of a catch 22 wherever i put the tank. Inside the frame rails will make a lot more sense though. I got the idea because i used to own a (TADAHH!) 1973 C-10. Either way it's a way down the road.
Matt
__________________
Old 06-15-2002, 11:57 AM   #9
rustbucket
Registered User
Do you have a web site for Speedballs?
rustbucket is offline   Reply With Quote
Old 06-16-2002, 12:21 PM   #10
dvalentine
Charter Member
dvalentine's Avatar
Look in this thread. Speedball listed his web site.
__________________
Old 06-30-2002, 12:35 AM   #11
David
Registered User
I was in a real bad auto accident in 1984, when I was 5 years old. My gradpa, Uncle, Dad, and Me were in a 1965 GMC, and we were HIT on the drivers side by a diesel doing 60+ miles an hour or so, while we were turning onto a dirt road. The gas tank did tear open from the impact, and DID NOT EXPLODE.
To make a long story short, the gas tank behind the seat IS as SAFE AS UNDER the bed between the frame rails.
I own a 62' Chevy C10, and I am happy to have the tank inside the cab with me.
David
David is offline   Reply With Quote
Old 06-30-2002, 01:04 PM   #12
dvalentine
Charter Member
dvalentine's Avatar
David, I'm glad that you made it out of that collision OK.
I do disagree with you though. There is no way that 16 gals of highly explosive material confined to the inside of a truck cab and two feet away from the occupants is as safe as placing that same material ten feet away from you outside the cab. Remember too that these are 30 year old vehicles we are talking about. Like everything else that old, because of age, things deteriorate. That includes fuel tanks. Common problem: " everytime I fill my truck up, I smell gas in the cab." Answer; leaking filler neck that spills contents out everytime you make a right turn. Take that situation and thrown in a collission. Not a good outcome.
Dennis
__________________
Old 07-02-2002, 01:02 AM   #13
David
Registered User
Hi Dennis,
I do agree to an extent on the tank being inside with me. I have all new parts for the tank, except for the tank itself. I have no smell of fumes in the cab, or when I make a right turn. But trying to restore her to the way she rolled off the assembly line has become a little challenging to find correct parts.
The reason I said the tank was as safe as inside, as is outside was because my friend was in his truck stopped at a light about a month or so ago, and was rear ended. The tank ruptured, and the fumes were lit from the hot exhaust. Since then he purchased a new (old)truck.
David
Old 07-30-2002, 11:44 PM   #14
MikeRS17
Registered User
HI will this work for a 1960 pickup with the rear springs in the back?
MikeRS17 is offline   Reply With Quote
Old 07-31-2002, 12:11 PM   #15
dvalentine
Charter Member
dvalentine's Avatar
>I have done a lot of buisness with our host but certain
>situations have forced me to look elswhere for my parts. I
>have found a underbed poly tank suitable for 63-66 Chevy and
>GMC trucks at Brotherstrucks.com . It is reasonbly priced
>at 269.95 plus S&H. Good Luck with moving your fuel tank
>from insided the cab. }>
Ralphy, WATCH THAT TANK !! The poly tanks from our friends over at the "other" supplier are noted for hanging down way too low. Like 3 to 6 inches below the differential. Not a good thing to have that much fuel in a position to be punctured by road hazards.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Gas tank relocation DrMike General Chevy & GMC Pickups Talk 13 09-15-2011 12:11 PM
Gas tank relocation bigdan473 1967-1972 4 07-12-2011 09:04 AM
Gas Tank Install choperules 1973-1987 2 12-29-2007 01:57 PM
Looking for a gas tank dngaspersich 1947-1954 6 09-10-2006 10:52 PM
Gas Tank Relocation mgoose22 General Chevy & GMC Pickups Talk 3 11-06-2002 07:33 PM
Powered by vBulletin® Version 3.8.9
