Reproduction Hood
Discussion in '1947-1954' started by oldyeller, Jun 5, 2012.
  1. oldyeller
    oldyeller Member
    I was wondering if anyone could tell me if the reproduction hoods they are making now for the 47 -54 chevy truck are any good ,how do they fix ,etc.
    i have a 52 and not sure to buy a repop or find a nice orignal . Thanks
  2. Raz76
    Raz76 Member
    -okc-
    They don't make them like they used to. I would find a good original that are out there, and go from there. Im gonna try to use as many original parts as I can as far as the body goes.
  3. Root2812
    Root2812 Member
    Coon Rapids, Mn
    Here is a thread where the guy bought a reproduction hood and it didn't fit right. He ended up buying an original hood and was happier. I'm sure he will post up here one of these days. https://talk.classicparts.com/showthread.php?t=17104
    Where are you from? I happen to have 2 extra hoods laying around :)
  4. My51
    My51 Member
    Minneapolis
    Root you are so right. I bought an aftermarket hood and it didn't fit. Like Root said, you are better off finding an original. Unfortunately for me I was already in the paint process when I had to change to an aftermarket hood because my original was to warped to bad to repair. The good thing is I believe Brother's is going to give me a full refund even after it was painted. A few things to look for if you buy one. First, the hinge threads were metric instead of standard. Second, they rolled the metal where it meets the cowl so that you can't get your 1/8 adjustment from hood to cowl. You can find a cheap original out there that you can fix for the $700 you will spend on an aftermarket.
  5. oldyeller
    oldyeller Member
    Thanks for all the input it sounds like i will have to look for a orignal hood.
    thanks Mark
  6. Kens 50 PU
    Oldyeller, tell us where you live, as it might help you in finding an original hood close enough to you that shipping won't "eat your sack lunch!"
  7. My51
    My51 Member
    Minneapolis
    Update: Brothers did refund my money on the bad hood and let me keep it. So now, what to do with it.
  8. vwnate1
    Scrap Hood
    Consider standing it on end and using it as a palette for doodles or whatever...
    In you're in Snow Country , weld a chain to it and use as a tobbagan .
  9. tims37
    tims37 Member
    Find another hood weld them together and you got your self a boat
  10. 1 Hotrod
    1 Hotrod Member
    Wisconsin
    or wait till winter and use it for a sled. I'm surprised you got a refund on it, they must have had problems with others and don't want the negative feedback.
  11. My51
    My51 Member
    Minneapolis
    Hood
    I think I got the refund because I had called originally on the metric threads on the hood. They were aware of that but had my call on record. They also had me send in the pictures of it not fitting to use as proof. I think they waited until they collected from the hood manufacturer before giving me the refund.
