Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1967-1972
1967-1972 Discuss all aspects of your 1967-1972 Chevy or GMC Pickup
Reply
Old 04-05-2005, 08:30 PM   #1
wilson
Registered User
Send a message via AIM to wilson
700r4 into a 72 Longbed
What is needed besides the driveshaft to make this work? How about shifting linkages and speedo cables? My dad passed this truck onto me since he is now in a nursing home and unable to do anything with it. I plan on making it my daily driver so an overdrive is a must. Any help would be greatly appreciated. I look forward to chatting with alot of you in the future.
Thanks,
Wilson
wilson is offline   Reply With Quote
Old 04-05-2005, 10:34 PM   #2
dvalentine
Charter Member
dvalentine's Avatar
RE: 700r4 into a 72 Longbed
Hi Wilson,
Very sorry about your Dad. Let's see if we can help. A bit more information is needed. What is in the truck now in the way of motor and trans ?
DVal
__________________
1964 C10 Panel 350 HO Crate and 700R4
1937 Ford Cabriolet ZZ4 & Tremic 5 speed
dvalentine is offline   Reply With Quote
Old 04-06-2005, 05:42 AM   #3
wilson
Registered User
Thanks DVal. The current and original combo is 350ci/TH-350 with the 2-piece driveshaft.
Wilson
Old 04-06-2005, 10:08 AM   #4
dvalentine
Charter Member
dvalentine's Avatar
[updated:LAST EDITED ON Apr-06-05 AT 10:13 AM (CST)]Thanks Wilson, that helps.
All that should be necessary is to move the trans crossmember back. If this is a short bed you can also go with a one-piece driveshaft.
If the current drive shaft trans yoke has the correct spline count you can re-use that on the new drive shaft. DONOT install a 700 r4 drive shaft yoke ! They have a vent hole that will leak everytime you park it. Use the TH350 yoke, as it has no vent hole.
You will need a TV cable. Check out the TV 101 article located at http://www.700r4.com. Read it a number of times but don't let it scare you. You will see that setting up the TV cable is very crucial to keeping the 700R4 from destroying itself.
Speedo cable will work, but you will need to match the drive gear in the trans to your wheel/tire combination and rear end ratio.
If you want to keep the column shifter, check out Lokar. The column indicator will not be correct and you will not be able to manually shift into 1st gear, but most folks don't seem to mind that too much.
If you want to go floor shift the Lokar Nostalgia Shifter is very close to the factory Granny 4 speed shifter and looks good in there.
Let us know if I got most of your questions.
DVal
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
700r4 computer jason6101188 1947-1954 3 11-22-2006 07:51 AM
1966 c-20 longbed fleetside 283 man 1960-1966 12 09-23-2006 03:27 AM
63 longbed fleetside audioclass 1960-1966 23 09-18-2006 09:25 PM
700R4 pearldrumbum 1960-1966 5 11-27-2005 05:15 PM
FOR SALE/TRADE/WANTED LONGBED STEP 57GMC Truck Parts for Sale 1 04-22-2002 01:28 AM
Powered by vBulletin® Version 3.8.9 Beta 4
