Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1955-1959
1955-1959 Discuss all aspects of your 1955-1959 Chevy or GMC Pickup
Reply
Old 07-28-2006, 07:56 AM   #1
58 Chevy pickup
Registered User
Rear for my 58 Chevy
I need some feedback about a new rear that I want to put in my 58 Chevy. What I would like is a 12 bolt posi 3:73 rear. I've been told that this is not a good rear to use because of the C clips that hold the axles in place, your opinions? I've already purchased the disc brake kit for a 12 bolt rear and would like to use them. I,ve read that a 70 to 81 Camaro rear is pretty much an even swap, is that correct? If that's the case where can I find one of these rears? I've tried local junk yards without any luck. Does anyone have a rear that they want to sell? I'm located in Maryland. Thanks Les
58 Chevy pickup is offline   Reply With Quote
Old 07-30-2006, 03:40 PM   #2
58 Panel
Registered User
Les,
You're behind the 8 ball pretty much hunting this rear end. Few were produced; for one thing most Camaros were lower performance & got the ten bolt housing, for another even fewer Camaros were standard shift & 3.73 is a standard shift ratio (except in trucks). The C clip issue doesn't bother me except when wheel hop is present (broken axles & spider gears) or on roundy round racetracks (side thrust issue). The one ray of hope I have for you is to hound the racer types. They often have scrounged sources & dug up such. They'll know of the rarity though, so get ready to part with some coin!
58 Panel is offline   Reply With Quote
Old 08-02-2006, 07:46 PM   #3
mcarrel
Registered User
Send a message via AIM to mcarrel
Rear Axle I used
I have a 57 with a 58 front clip. I used a Ford 8.8 out of a 88 Tbird Turbo Coupe. It is a 3.73 limited slip with disc brakes it is just the right width 59 1/2. I bought new axles to get the right bolt pattern and new brackets so inexpensive 94-2004 stock mustang disc brake parts fit. Let me know if you have any questions. My new Heidts 4-link came in today so I will be setting up the rear suspension in the next week. I hear the Ford 9 inch rear work well if you can get the right width. You can see my project here http://tagworld.com/azmark/
__________________
McGyver
mcarrel is offline   Reply With Quote
Old 08-25-2006, 11:35 AM   #4
57 restomod
Registered User
I used an 8.8 too
Les, I used an 8.8 Ford rear too. They are a strong rear and they are plentiful at the wreckers. Mine is a 3:73 ratio and came out of a 98 Ranger 4x4 and has 10" drum brakes. There are a few ratios, I even saw a 4:11. I actually swapped the entire assembly of frame brackets, springs, brake cables and sway bar from the Ranger. I removed the 2 1/2" lift shims and moved the spring perches from on top to below the axles and moved each 5/8" inward because the 57 frame is 1 1/8" narrower than the 98 Ranger.
57 restomod is offline   Reply With Quote
Old 08-26-2006, 08:29 AM   #5
58 Chevy pickup
Registered User
Ford rear
The Ford 8.8 rear sounds like the way to go. Where did you get the chevy axles for the Ford rear and where they difficult to install? Thanks Les
Old 08-26-2006, 10:37 AM   #6
mcarrel
Registered User
Where I got my axles
Actually I am using a 5x4.5 bolt pattern not the Chevy. I got my axles from www.northracecars.com/ a real nice guy to deal with. Ask for Richard he was very helpful and should be able to make axles for you if he can't he will explain why and offer suggestions. He is very knowledgeable with the Ford stuff. Good luck. You can see my project here http://tagworld.com/azmark/
__________________
McGyver
Old 09-01-2008, 09:43 PM   #7
step1958
Registered User
i bought a 12 bolt leaf spring style out of 69-70 pickup six lug bolted right in didnt even have to change spring purches or re set pinon angle its 3;73 posi also !!!!!
step1958 is offline   Reply With Quote
Old 09-01-2008, 09:54 PM   #8
Matthew
Registered User
Matthew's Avatar
I got a Ford 9" out of a 500 GT
Bolts right in and the exact width i needed
__________________
1957 3200 long bed 327 TRW forged pistons, High volume/High pressure oil pump, Melling steel oil pump drive, GM "General" 327/350hp cam, 1.6 Lunatie roller tip rockers, 52cc heads, 10qt. Milodon pan, CVR mini starter, Accel Super coil dubble hump 2.5 collector manifolds, Edelbrock Streetmaster intake, Holly 600cfm carb., more to come.....
Matthew is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1948 Chevy Barn (rear) Doors rxbrewer Truck Parts Wanted 1 04-23-2008 06:15 PM
1951-56 Chevy 6 lug 10 bolt rear end badassstepside Truck Parts for Sale 3 09-24-2007 09:29 PM
Rear bumper needed for a 1954 Chevy bennyhunch Truck Parts Wanted 0 03-30-2007 09:58 AM
small rear window 58 chevy apache 3 SATINDOG 1955-1959 2 09-20-2004 09:43 AM
for sale '63 chevy rear control arm beanbagsj Truck Parts for Sale 0 12-09-2003 11:43 PM
Powered by vBulletin® Version 3.8.9 Beta 3
