Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > General Chevy & GMC Pickups Talk
General Chevy & GMC Pickups Talk General Discussion Forum for all Chevy and GMC Pickups
Reply
Old 04-02-2001, 08:43 PM   #1
DrMike
Registered User
DrMike's Avatar
Gas tank relocation
I seen several postings in the past about the same subject but have never seen a clear cut answer to any of them.
Has anyone out there found a viable option for relocating the gas tank from behind the seat to under the bed on a 55-59? Any real options please leave a reply.
DrMike
__________________
'58 Stepside
305 engine and 350 tranny
DrMike is offline   Reply With Quote
Old 04-14-2001, 11:40 AM   #2
mike 54
Registered User
RE: Gas tank relocation
Using the chevelle tank on my 54 worked great, but am not sure how well it will work on the 55 2nd series it seems that it will work okay. My neighbor saw mine then decided to try it on his 56, but hasn,t done it yet. Probably because the chevelle tank that he had was the one that I used.
mike 54 is offline   Reply With Quote
Old 04-23-2001, 09:22 PM   #3
Greatsix
Registered User
I found a Gas tank I believe from an 85 ford pickup rear mount, My TF is a long wheel base so I put it the area of the spare tire, so I would not have to relocate the crossmember, the tank is deep but it lets me use the stock sending unit,and I will be using a electric fuel pump, If you like I can send you pictures of how I mounted it. The only problem so far is the orignal sending unit has a strange thread I used a 2 1/2 fire hydrant cap and lot of silicone.
Billy Gibson dba HooT58
Greatsix is offline   Reply With Quote
Old 04-30-2001, 09:42 PM   #4
my56
Guest
Posts: n/a
yes, email me at p.legates@att.net. CD seems to cut out my directions to a webpage that has a tech artical on how to install the blazer/ suburban tank from 69 to 73.
Old 05-02-2001, 01:22 PM   #5
Craig
Guest
Posts: n/a
Unfortunately the Blazer gas tank is too big to fit under the bed of the 1955-59 pickups.There is a company called Tank,Inc that makes a drop in steel tank.That are not expensive compared to the stainless tanks.I will do some checking and see if they have a web site or literature so everyone can look at it.
Craig Hager
tech1@chevyduty.com
Old 05-04-2001, 10:26 PM   #6
mark57
Registered User
I found a tank from a 1977 postal jeep 16x21x10deep. I modified the stock 57 truck sending unit to fit and mounted the filler neck behind the lic plate.
mark57 is offline   Reply With Quote
Old 01-07-2008, 03:19 PM   #7
islasj
Registered User
Quote:
Mike 54
Do you remember the year of the chevelle, that you used the gas tank from?
islasj
Thanks
islasj is offline   Reply With Quote
Old 06-28-2008, 05:47 PM   #8
sweet50
Registered User
sweet50's Avatar
I went custom, well kind of. I mounted a 16 gal fuel cell under the bed.
http://store.summitracing.com/partde...5&autoview=sku
Brand: Summit
Product Line: Summit Pro Street Fuel Cells
Part Type: Fuel Cells
Part Number: SUM-290108
Capacity: 16 gallons
Fuel Cell Color: Black
Fuel Cell Material: Plastic
Foam: Yes
Sending Unit Included: Yes
Sender Ohm Range: 0 ohms empty, 90 ohms full
Length (in): 25.000 in.
Width (in): 17.000 in.
Height (in): 9.000 in.
Outlet Fitting Quantity: Two
Outlet Fitting Size: -8 AN
Return Fitting Size: -6 AN
Sump: Yes
Sump Depth (in): 2 in.
sweet50 is offline   Reply With Quote
Old 07-29-2008, 11:33 AM   #9
drabo
Registered User
drabo's Avatar
Talking
I was thinking about doing that swap also but have since changed my mind. I'm now thinking about installing a cut-off switch inside the cab and a locking gas cap. By having my gas tank inside the cab it is harder for theifs to slide under the bed, drill a hole in the tank and steal all my liquid gold. The switch and gas cap will keep all that fuel safely inside the tank where I can use it up and then take another morgage out to get another tank. Just a thought.
__________________
66 Chevy C10 "The Nugget" 283/700R4
drabo is offline   Reply With Quote
Old 12-17-2009, 07:28 PM   #10
hondoe1
Registered User
They make a tank now that will bolt right to the frame.LMC has it for around a hundred bucks.
hondoe1 is offline   Reply With Quote
Old 02-02-2011, 09:05 AM   #11
Lee P
Registered User
Lee P's Avatar
Hi Mike my name is Lee Peters I have a 53 chevy truck and I also would like to move the tank under the truck do you have any Pitchers? and what year of chevelle did you use thanks.
LEE.
Lee P is offline   Reply With Quote
Old 02-08-2011, 04:13 PM   #12
Lakeroadster
Registered User
Lakeroadster's Avatar
Quote:
Craig Hager
tech1@chevyduty.com
Actually the company you are refering to is Tanks, Inc. Here is their website: http://www.tanksinc.com/index.cfm
Dr. Mike,
I personally don't like any of the tanks that are visible hanging under the truck as viewed from the back or side. The blazer tanks hang down and the '69 Camaro tanks that seem to now be the rage also hang down below the rear bumper. Looks like an afterthought, IMO. I used a Tanks, Inc. 49-52 Chevrolet passenger car tanks on my 1965. You can find pictures, some instructions and parts list on post #8 here: http://67-72chevytrucks.com/vboard/s...d.php?t=444378
Here is my tank set-up
And some drawings I made. These should help you to determine if the tank will fit in your frame.
And here is an article from Classic Trucks for installing a gas tank in the rear of a 1957 1/2 ton: http://www.classictrucks.com/tech/10...ton/index.html
I hope this helps. If you have any questions on the tank I installed feel free to ask, always glad to help.
__________________
Inspired to be different. Different in a way of my own, not in a way that others strive.
"The Orange Crate" 1965 C10 SWB Step Side Build Thread
Some Technical Threads I Have Authored:
Frame Mounted Gas Tank --- Rear Frame Notch --- Upper Shock Relocation --- Track Bars, The Long & The Short Of It --- Cab / Bed Step Gravel Guards ---
A smart man learns from his own mistakes, a wise man learns from the mistakes of others.
Lakeroadster is online now   Reply With Quote
Old 02-13-2011, 03:22 PM   #13
Lakeroadster
Registered User
No doubt that's the best place for the tank. I would have liked to have done that on my '65, but with the coil sprung stock trailing arms there is no room.
__________________
Old 09-15-2011, 12:11 PM   #14
justplainray
Registered User
this one is out of
a 1959/60 Chevy passager car
Had to shorten the neck. Home made straps to hang it, used frame cross member forward and bed rear sill for attachment points.
the best part is that the car sending unit is compatible with the truck gas gauge.
Used a Nova flip-up license plate to find the filler, removed in this photo for paint job.
justplainray
justplainray is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Gas tank relocation bigdan473 1967-1972 4 07-12-2011 09:04 AM
Gas tank relocation bob39666 1960-1966 28 09-28-2010 01:58 PM
Gas Tank Install choperules 1973-1987 2 12-29-2007 01:57 PM
Looking for a gas tank dngaspersich 1947-1954 6 09-10-2006 10:52 PM
Gas Tank Relocation mgoose22 General Chevy & GMC Pickups Talk 3 11-06-2002 07:33 PM
Powered by vBulletin® Version 3.8.9 Beta 4
