Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1947-1954
1947-1954 Discuss all aspects of your 1947-1954 Chevy or GMC Pickup
Reply
Old 01-04-2007, 08:36 PM   #1
Poppy Wagon
Registered User
Wiring in a S-10 tilt column
Anyone here know which colored wire goes to where from the steering column? Been trying to find a wiring diagram on line,Thanks
Poppy Wagon is offline   Reply With Quote
Old 01-04-2007, 08:45 PM   #2
Kens 50 PU
Registered User
Kens 50 PU's Avatar
Hey Poppy Wagon, I don't have a clue but, Coilover or Kevins48 will surely know the answer. But, i have a question. How did you come up with your handle? That takes me back to my college days, when you had to have a mid 60's van to cruise in. I had a '66 F**d econoline van with "Keep on Truckin'" stenciled on the side. Of course, i was labeled a dope smokin' hippie and every mother's nightmare. But then again, I was ONE mother's nightmare!
Kens 50 PU is offline   Reply With Quote
Old 01-04-2007, 10:58 PM   #3
federale
Registered User
federale's Avatar
I put an early 80's Monte Carlo column in my 53 without a diagram. What I did was lay it out on the workbench and hooked the battery charger to it and used a test light to chase down all the wires. Hope this helps!
__________________
Chevy Duty Charter Member
federale is offline   Reply With Quote
Old 01-04-2007, 11:13 PM   #4
Kevin's 48
Registered User
Kevin's 48's Avatar
what year S-10 and I'll try to find out for you.
__________________
Ah, that's no big deal!
Kevin's 48 is offline   Reply With Quote
Old 01-05-2007, 12:00 AM   #5
Boopster
Registered User
Boopster's Avatar
Wire to what?
I put an 80 camaro tilt wheel in the Boops ride. Used an ohm meter to locate what did what. Put it in and everything worked right the first time. I wrote down what color everything was and I'm gona try to find it to post here. Seems these days that the best working part of me is "MY FORGETER"
anyway, ohming it out went fast and error free, maybe this will help
TB'sD
__________________
The Boops Metalic Candy Apple Red Ride
Boopster is offline   Reply With Quote
Old 01-05-2007, 02:00 PM   #6
Poppy Wagon
Registered User
S-10 column
Hey,I got the name poppy wagon because when my brother and I were young we called old trucks and cars poppy wagons! Also the steering column is from a 1991, Thanks!
Old 01-05-2007, 07:32 PM   #7
Kevin's 48
Registered User
Kevin's 48's Avatar
Hey Poppy still searching for that diagram that i have, but in the mean time if you find any GM 5 wire steering column diagram it will be the same as what you have on yours.
__________________
Old 01-05-2007, 09:13 PM   #8
Kevin's 48
Registered User
Kevin's 48's Avatar
I might have found it, let me know if this is the same harness colors that you have and maybe even test it with a test light to see if it matches. Hope this helps.
Wiring Schematic
White - Brake Feed
Green - Right rear turn signal and break
Yellow - Left rear turn signal and brake
Purple - Turn Feed
Brown - 4 Way Feed
Dark Blue - Right front turn signal and indicator
Light Blue - Left front turn signal and indicator
Black - Ground for horn relay
__________________
Old 01-07-2007, 09:57 PM   #9
Poppy Wagon
Registered User
S-10
Thanks !!!!!! I wrote that down and will try that out as soon as I get a chance.
Old 01-10-2007, 02:31 PM   #10
52wasp
Registered User
Hey Poppy,
I sure do read more than I write on this forum. Finally something I know about.... I have a factory 92 wiring diagram for S10 (11x17, hundreds of pages for every option, pickup/blazer). If you want I will look up the wire info for you and post it or even scan in the areas in question. Mike
52wasp is offline   Reply With Quote
Old 01-11-2007, 09:51 AM   #11
Poppy Wagon
Registered User
Smile S-10
Thanks Wasp, I sure could use some info on the wherabouts of the large gauge wires ! I sure would like to get that part done, then on to the rack and pinion, Pacer suspension!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1960-66 chevy truck Ididit chrome tilt steering column stevemd65 Truck Parts for Sale 0 08-16-2008 08:28 AM
Steering Column Wiring Question Texas53 1973-1987 4 04-27-2008 06:59 PM
1971-72 tilt steerring column parts nook 1967-1972 1 12-27-2007 11:41 PM
steering column wiring BamaJohn66 1960-1966 2 03-15-2005 11:58 AM
87 steering column wiring BamaJohn66 1973-1987 1 03-02-2005 11:33 AM
Powered by vBulletin® Version 3.8.9 Beta 4
