Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1967-1972
1967-1972 Discuss all aspects of your 1967-1972 Chevy or GMC Pickup
Reply
Old 03-13-2007, 06:55 AM   #1
69c10step
Registered User
69c10step's Avatar
Disc brake conversion
I am looking at all the different choices for converting the manual brakes on my '69 C10 to power disc / drum.
Any thoughts on who sells the best complete kit? Also, I see that some places have rear disc conversions and others do not. Are rear disc brakes necessary?
Any thoughts or experiences would be helpful.
Thanks
69c10step is offline   Reply With Quote
Old 03-13-2007, 07:13 AM   #2
OLDIRON69
Registered User
The '71 C10 I had sported front disc/rear drum. It stopped fine and I never personally saw a reason to go 4 wheel disc, ease of brake repair alone would make me lean to the rear swap as well though. I HATE DRUM!
__________________
'69 C-10 350/3spd
OLDIRON69 is offline   Reply With Quote
Old 03-13-2007, 05:03 PM   #3
drabo
Registered User
drabo's Avatar
CPP has plenty of options.
__________________
66 Chevy C10 "The Nugget" 283/700R4
drabo is offline   Reply With Quote
Old 03-16-2007, 08:22 AM   #4
OLDIRON69
Registered User
Blew front tire yesterday, drum brakes locked up on me and pulled me into the curb!
Are there any other yrs that will swap? 73-87??? I found a '71 with front disc so may be going that route.
__________________
'69 C-10 350/3spd
Old 03-16-2007, 12:45 PM   #5
drabo
Registered User
drabo's Avatar
73-87 will fit
__________________
Old 03-20-2007, 09:00 AM   #6
OLDIRON69
Registered User
The spindles, rotors, calipers and all will swap over? How about the rear axles? I want 5 lug all the way around. Thanks in advance for the help!
__________________
'69 C-10 350/3spd
Old 03-20-2007, 10:20 AM   #7
dvalentine
Charter Member
dvalentine's Avatar
Two options for 5 lug rear.
1) swap in a 72-or later rear with 5 lugs.
2) Use the replacement axle conversion kit from Early classic Enterprise.
some would also suggest re-drilling the rear hubs to 5 stud and having the 5 lugs welded in. You might have trouble finding a shop to do that because of liability risks.
Val
__________________
1964 C10 Panel 350 HO Crate and 700R4
1937 Ford Cabriolet ZZ4 & Tremic 5 speed
dvalentine is offline   Reply With Quote
Old 03-20-2007, 11:11 AM   #8
69c10step
Registered User
69c10step's Avatar
When converting to disk brakes, is a wheel change a must?
Old 03-20-2007, 11:55 AM   #9
OLDIRON69
Registered User
Having rear trailing arms/coil springs, will any '73 and up 5 on 5.5 truck rear swap right into my stock rear's place? I have a friend that has the front set up out of a '72,so I'm good there. I will just need to locate a rear end.
__________________
'69 C-10 350/3spd
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
5 lug on 4-3/4" disc brake conversion parts drummin52 Truck Parts Wanted 0 01-07-2009 08:56 AM
Rear Disc Brake Conversion BUB91 General Chevy & GMC Pickups Talk 5 01-06-2005 12:28 PM
front disc brake conversion machinehead 1960-1966 3 10-18-2003 12:01 PM
disc brake conversion kits kychevy 1960-1966 1 02-11-2002 11:34 AM
66 Disc Brake Conversion jeremy 1960-1966 5 02-04-2001 12:19 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
