Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1947-1954
1947-1954 Discuss all aspects of your 1947-1954 Chevy or GMC Pickup
Reply
Old 04-05-2007, 10:41 PM   #1
47chevyrod
Registered User
47chevyrod's Avatar
216 engine problem
OK so I have my 47 chevy the last time I drove it It was running fine and all of the sudden it got hot and I looked and it was poring water out of the back of the motor. The motor still runs fine it just leaks water very fast. I got started changing the motor first off by building a new one. I decided to put a 250 in it but as I was taking the pressure plate off the 250 I saw the freeze plugs and it hit my maybe my block isnt cracked maybe a freeze plug came out. I havent pulled the 216 yet because it still runs and at least I can run it long enough to move it in and out of the barn. So my question is, are there freeze plugs on the back of a 216 a guy told me there wasnt any. The water runs out into the belhousing so it makes since that it could be one out if there are any
47chevyrod is offline   Reply With Quote
Old 04-06-2007, 10:55 AM   #2
Kens 50 PU
Registered User
Kens 50 PU's Avatar
Have you checked to see where the coolant leaked out? It could be several different things. My initial thought was that you blew a head gasket. Check your oil to see if it looks milky. IIRC, the 216 had a freeze plug on the driver's side under the manifold about half way between the front and back of the length of the motor, slightly more towards the front.
__________________
Every morning is the dawn of a new error
Kens 50 PU is offline   Reply With Quote
Old 04-06-2007, 12:10 PM   #3
47chevyrod
Registered User
47chevyrod's Avatar
My oil isnt milky at all I cant really tell were the water is coming from but when its running it sloshes around the flywheel and runs out of the botom of the belhousing and runs out under the the belhousing and out of the hole above the starter.
Old 04-06-2007, 02:28 PM   #4
Kens 50 PU
Registered User
Kens 50 PU's Avatar
click on this link and it will show what an original 216 looks like. Could your problem be the draincock located near the back of the block? http://www.chevy.tocmp.com/1929_54ch.../info/085a.htm
__________________
Old 04-06-2007, 03:38 PM   #5
vwnate1
Registered User
vwnate1's Avatar
Post
Wow ~ it's been so long since I had a 216 I've forgotten but most Inline engines do have a Welch plug behind the flywheel , it is a simple thing to drop the tranny and then the flywheel so you can look , without touching the engine , that'd be what I'd do .
Keep us posted please .
__________________
-Nate
' PASSION ' :
There are many things in life that will capture your eye , very few will capture your heart ~ those are the ones to persue .
Those are the ones worth keeping .
vwnate1 is offline   Reply With Quote
Old 04-06-2007, 04:01 PM   #6
Kens 50 PU
Registered User
Kens 50 PU's Avatar
Location of back freeze plug?
Nate, is this what you're talking about?
http://www.picayuneclassics.com/1953...re-engine7.jpg
http://www.picayuneclassics.com/1953...inside_4x6.jpg
__________________
Old 04-06-2007, 04:13 PM   #7
vwnate1
Registered User
vwnate1's Avatar
Thumbs up OOOOooo ~ Pretty Engine Pix
Yep , that's it allright . you'll be able to see it once the flywheel is off .
You'll have to remove the bellhousing to replace it tho'
Be sure to use a brass replacement plug !
__________________
-Nate
' PASSION ' :
Old 04-06-2007, 06:20 PM   #8
47chevyrod
Registered User
47chevyrod's Avatar
as soon as I get a little time im going to see if thats were its leaking from. I really hope it is that would explain the water runing out very fast.
Old 04-06-2007, 06:59 PM   #9
Kens 50 PU
Registered User
Kens 50 PU's Avatar
Hope it works out for you!
Quote:
And always remember: My advise and 79 cents will buy you coffee at the "Stop and Rob" and 4 bucks and Nate's advise will buy you Starbucks!
__________________
Old 04-06-2007, 10:13 PM   #10
Chiro
Registered User
Chiro's Avatar
prolly the freeze out plug. Always the one that goes is the one that is the hradest to replace. Guaranteed, it's the one behind the block, uyp against the firewall. You know...the one that makes you pull the trans, clutch, flywheel and BELL HOUSING TO REPLACE. Cheaper than a rebuild, though.
Andy
Chiro is offline   Reply With Quote
Old 04-06-2007, 11:55 PM   #11
47chevyrod
Registered User
47chevyrod's Avatar
yea its always the part that is hardest to get to or the one they stoped making 20 years ago, or even better all the bolts come out easy until that last one that takes longer to get out than the last 10 because it twists off. Without all the things working on things wouldnt be any fun. I really hope it is that freeze plug that would be way cheaper and easyer than a new motor
Old 04-07-2007, 06:01 PM   #12
vwnate1
Registered User
vwnate1's Avatar
Exclamation Boy You Guys Said It !
I cannot tell you how many times the littlest thing becomes the largest problem , esp. when I tell the customer " oh , that ? not to worry , we'll fix that in a jiffy ! "
Robert Baird's 261 project turned sour when the water jacket opened up in the side of the cylinder block as it often does in 216's , 235's & 261's that were run on plain water for years and years.... right behind the generator...
Of course , if I tell the customer to expect the worst and lay out all the various ways the job might go badly and how it'll suck his wallet dry , it'll all go smooth as silk and then they think I'm either an idiot or worse crooked and tried to set them up for fleecing...
__________________
-Nate
' PASSION ' :
Old 04-08-2007, 06:09 PM   #13
cmkruse
Registered User
cmkruse's Avatar
Loved the Engine Picture
This is for Kens 50 PU, sorry about off topic but the engine picture was great and the paint job is super - what is it painted with and is that an original color for a 235 or just the 216?
Thanks Craig
__________________
Forum friends thanks for all the help - past and present!
Craig / 49 Panel
cmkruse is offline   Reply With Quote
Old 04-08-2007, 06:49 PM   #14
Kens 50 PU
Registered User
Kens 50 PU's Avatar
Yeah I loved it too...
Quote:
Thanks Craig
Too bad it's not mine. I did a "google" search to see if I could come up with a good shot of a 216 to show where the freeze plugs were located.
__________________
Old 04-08-2007, 08:17 PM   #15
cmkruse
Registered User
cmkruse's Avatar
Arrow Foiled once again batman!
Okay Kens 50 pu just my luck. I'll try and backtrack the website from the other post. Sorry it weren't yours
__________________
Craig / 49 Panel
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Adjusting Hydraulic Lifters on a 23 Bossman 1947-1954 10 08-05-2010 10:12 AM
Help! Do I have a 1954 Corvette Engine? bfrisby 1947-1954 11 03-19-2009 08:38 PM
Big Problem???? Chiro 1947-1954 7 08-11-2007 04:39 PM
Engine will not start. NEED HELP! General 1960-1966 11 01-25-2003 01:20 AM
Engine Problem Smokinn 1973-1987 6 11-13-2002 03:58 AM
Powered by vBulletin® Version 3.8.9 Beta 4
