Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1947-1954
1947-1954 Discuss all aspects of your 1947-1954 Chevy or GMC Pickup
Reply
Old 07-16-2006, 08:36 AM   #1
coilover
Registered User
S10 frame swap pictures
Guys, I apologize for my lack of computer skills which prevents me from knowing how to put text with a photo but with patience to match the verbal discription to the pictures maybe it will help others out who undertake this job. Go to http://www.msnusers.com/Evanscars and click "pictures", "show photos", pages 1 and 2 to view.
S10-014: S10 cab coming off(gas tank can be used like a 47/48)
S10-025: AD cab with beam through cab--unbalanced
S10-026: 100# wt. hung on bar bolted to top radiator mount holes
S10-027: chain on top hinge pocket bolts--perfect balance w/wt.
S10-028: AD-engineering cab mounts in place w/temp metal screws
S10-031: bed crossmembers bolted to bed(use spacer under angle strip}
S10-034: test fit of bed and cab before final bolts in mounts
S10-035: modified rear RB bracket to give spring hanger clearance
S10-038: wheel fit in stock S10 location--too narrow
S10-039: wheel fit with 2" spacer(tire centered under headlight)
S10-041: stock AD tire location
S10-044: column tube moved to top of hole,new shifter rod hole
S10-047: modified shifter rod to clear dash with column moved up
S10-049: S10 E-brake equalizer on shortened and threaded AD rod
S10-050: 3:1 accelerater bellcrank to open carb all the way
S10-051: radiator up 2" to clear steering gearbox
S10-053: ford accel.cable has integral cable and return spring
S10-054: flat spot milled on intake to accept temp bulb fitting
ModA-017: welded on 1/2" plate drilled and tapped for stock S10 mt.
ModA-028: 16 g plate welded to bottom of column, screws in AD holes
Cecils 40 PU-007: access holes cut to reach S10 motor mount nuts
Cecils 40 PU-001: modified lower radiator pan(air baffle)
Will post the bumper mount bracket set up and finished pics later;Evan
__________________
Evan
coilover is offline   Reply With Quote
Old 07-22-2006, 02:07 AM   #2
coilover
Registered User
RE: S10 frame swap pictures
Pictures S10 055 shows a fabricated neutral safety switch that works well (use an all weather boat or tractor start button), and S10 057 and 058 show the extended front bumper bracket arms on the S10 frame. Once these spring steel arms are welded on the're only good for holding the bumper in place, no longer functional.
__________________
Evan
Old 08-15-2006, 06:19 PM   #3
coilover
Registered User
The site the pictures are on only allows 3mb. I got the rear bumper mount pictured, 6" piece of 2 1/2" square tubing plus a 2 1/2 by 6" piece of 3/8 plate for spacer( 2 7/8" total), each side. This makes the perfect width for the bumper brackets to slide on with a squeak fit. In fact you have to make a hole for the head of the rivet that holds the two bracket arms together or it's too tight. I wanted to make some finished pics but used up my allowable 3 mb.
__________________
Evan
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Frame swap? 65Matt Chassis & Suspension 5 10-11-2011 08:05 PM
55-57 frame swap racerdon Chassis & Suspension 1 07-03-2008 02:56 AM
frame swap question wschmpn 1947-1954 11 12-15-2007 06:05 PM
s-10 frame swap/v8 swap josh_brown162 1947-1954 3 02-02-2006 10:49 AM
59 fleetside frame swap austinjn 1955-1959 4 10-10-2005 05:42 PM
Powered by vBulletin® Version 3.8.9 Beta 4
