Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1947-1954
1947-1954 Discuss all aspects of your 1947-1954 Chevy or GMC Pickup
Reply
Old 04-09-2006, 07:42 PM   #1
ltcmikem
Registered User
Post 235 Lifters
My '49 GMC has a '54 235 in it. Engine serial # on the flat just aft of the distributor is 0818638F54X.
How can I tell if this engine has solid of hydraulic lifters?
Mike M
'27 Chevy
'41 John Deere B
'49 GMC FC-150
__________________
Mike M
'27 Chevy
'41 John Deere B
'49 GMC FC-150
ltcmikem is offline   Reply With Quote
Old 04-09-2006, 10:18 PM   #2
vwnate1
Registered User
vwnate1's Avatar
RE: 235 Lifters
Set engine to TDC on cylinder # 1 and then push down the heel of the rocker arm with your hand ~ if it has juice lifters the push rod will have *some* give to it .
I'm sure you have solid lifters unless it's a passenger car engine .
Hydraulic lifters don't work well on 235 engines do to the low pressure oiling system , they tend to clatter loudly at idle speeds when the engine is warmed up .
The rob quite a bit of power too .
Lastly , please to remember : this is an OLD TECH engine design and
" A Noisy Valve Is A Happy Valve " .
it should click like an old sewing machine .
Worn out rockers & shafts make far more noise than do solid lifters so rebuild the entire rockers and shafts before deciding you simply
-MUST- have juice lifters .
-Nate
__________________
-Nate
' PASSION ' :
There are many things in life that will capture your eye , very few will capture your heart ~ those are the ones to persue .
Those are the ones worth keeping .
vwnate1 is offline   Reply With Quote
Old 04-10-2006, 09:26 PM   #3
ltcmikem
Registered User
Post RE: 235 Lifters
Thanks for the reply Nate. I don't mind the valve clatter, just need to figure out if the lifters are solid or juice so I can adjust them correctly. I have no idea if the 235 came out of a passenger vehicle or another truck. Should I run the engine to pump up the lifters (if they're juice) before doing the test you suggested?
Mike M
'27 Chevy
'41 John Deere B
'49 GMC FC-150
__________________
Mike M
'27 Chevy
'41 John Deere B
'49 GMC FC-150
Old 04-11-2006, 06:49 AM   #4
vwnate1
Registered User
vwnate1's Avatar
RE: 235 Lifters
[updated:LAST EDITED ON Apr-11-06 AT 06:53 AM (CST)] _NO_ ~ you want them bled down so you'll be able to feel the ' give '
You can take off the tappet chamber cover on the side of the engine and look at the lifter tops where the push rods sit on them , if the lifter has a snap ring holding the two pieces to-gether , it's hydraulic .
You'll be able to see how much sludge this engine has in it too as this chamber is lubricated my oil returning from the head area .
You can also see by adjusting the valves with the engine warmed up and @ idle , when you turn the valve adjusting screw to _zero_ lash ,
a solid lifter will cause that cylinder to miss where a hydraulic lifter will all the engine to continure idling just fine , little or not audible click .
Many listers here have discovered mixed lifters , both solid and hydraulic , in the same engine so pulling the side cover might be wise
FWIW , I've never worried about it on the 235 in my old '49 shop truck , I just adjust them as solids a couple times a year .
-Nate
__________________
-Nate
' PASSION ' :
Old 04-11-2006, 07:53 PM   #5
ltcmikem
Registered User
RE: 235 Lifters
Got it Nate. Just the info I was hoping to get. Many thanks again.
Mike M
'27 Chevy
'41 John Deere B
'49 GMC FC-150
__________________
Mike M
'27 Chevy
'41 John Deere B
'49 GMC FC-150
Old 04-12-2006, 07:43 AM   #6
vwnate1
Registered User
vwnate1's Avatar
RE: So Now :
Tune the living heck out of it , do a couple _HOT_ oil changes and go DRIVE the doggoned thing ! .
Enjoy it !.
-Nate
__________________
-Nate
' PASSION ' :
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Adjusting Hydraulic Lifters on a 23 Bossman 1947-1954 10 08-05-2010 10:12 AM
Engine swap Q rix 48 1947-1954 10 09-12-2008 11:21 PM
oil pan for 1954 235 ccharr 1947-1954 22 09-01-2008 02:49 AM
Paint codes?? jbrown12308 1947-1954 19 06-02-2007 07:10 PM
Noisy Lifters Force5 1973-1987 3 04-08-2003 07:09 PM
Powered by vBulletin® Version 3.8.9
