Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1947-1954
1947-1954 Discuss all aspects of your 1947-1954 Chevy or GMC Pickup
Reply
Old 12-27-2007, 09:17 PM   #1
Hotrod53chevy
Registered User
Send a message via MSN to Hotrod53chevy
1953 Chevy V8 Conversion / Steering Box Clearance...
Say does anyone have any experience with the V8 conversion for the 47-54 Chevrolet trucks? I have the engine in but the clearance between the steering gearbox and the side of the drivers side #7 cylinder plug is extremely close and I havent got my exhaust manifolds on yet, any Ideas? let me know if you have had any luck with these and any pointers if you have any. Thanks Scott-
Hotrod53chevy is offline   Reply With Quote
Old 12-27-2007, 09:49 PM   #2
mylow53
Registered User
mylow53's Avatar
i installed a mustang 2 frount end, that usually fixes the problem... and causes many more.....
__________________
http://67-72chevytrucks.com/vboard/s...215079&page=16
1953 chevy 1/2 ton 5 window, lowering spindels mustang 2 frount. ford 9"notched rear, airbags on 4 corners. purchased in 1983 while in high school for $175.00
mylow53 is offline   Reply With Quote
Old 12-28-2007, 01:58 AM   #3
coilover
Registered User
Scott, it depends on what you want out of your V8. If you just want a modern drivetrain with parts available anywhere then a 55 or 56 chevy 265 V8 left exhaust manifold will fit. It is good for an engine that puts out about 225 hp with a good dual exhaust system. If you want big horses then this flat log type manifold won't cut it and it's either move the box or go to an IFS.
__________________
Evan
coilover is offline   Reply With Quote
Old 01-14-2012, 09:00 PM   #4
Gtown Larry
Registered User
Thumbs up 53 chev truck V8 swap
I'm doing the same swap as you right now. I used the tubular crossmembers from Classic Chevy. The steering box has to be moved outward by 1 1/4-1 1/2 inches. Make a plate, or angle, to weld, or bolt on top of frame to move it outward by this much, keeping the new st. box mounting surface flat w the old surface. Also in an article in an old magazine I have from 1955, doing this same swap, they also moved the box, and had a machine shop mill the flange of the drivers exhaust manifold down by about 1/2", and they didnt have to move steering so far. I'm using block hugger headers, and had to put small ding where adjustment nut is on side of box. You can also move the engine slightly to the left w/o any problems. The steering arm has to be heated, and bent back toward the frame so the drag link is parallel w the frame.
Another alternaive is as a neighbor of mine did with his 53, cut off entire frame under cab, and graft on a Camaro, or Nova subframe, that has P.S, Disc brakes, and V8 mounts. Gtown Larry
Gtown Larry is offline   Reply With Quote
Old 01-16-2012, 05:27 PM   #5
indybowtie
Registered User
indybowtie's Avatar
Scott
My 2 cents worth...my '48 had a bad steering box, weak springs, tired 6 cyl., and I wanted to install a 283, disc brakes, and so on. Knew I would have to get 265 rear dump manifolds and tubular engine mount to clear the stock box, new springs, disc brake kit, new steering box, etc. I jumped and bought a MII and solved all the problems with that. I was probably going to have $1500 in everything else if I did it with the stock design.
Just got it back on the road and loving it. Rides nice, sits low, stops great, steers sweet, good power with the 283, and of course with the inner fenders on you cannot see any of the front suspension if it matters.
Ps. I used the original column too!
indybowtie is offline   Reply With Quote
Old 01-17-2012, 06:56 AM   #6
tims37chevy
Registered User
Or if ya get the power steering kit it moves the box up front on out side of the frame rail
tims37chevy is offline   Reply With Quote
Old 01-17-2012, 08:30 PM   #7
penniwinkle
Registered User
penniwinkle's Avatar
v8 swap
I just recently completed a V8 install into my '51. Re the steeering box, I purchased a heavy piece of angle iron from h-depot, cut a piece about 6 inches long and mounted it outside the frame where the steering box bolts on and matched up the 'top of the frame holes' on top the the angle iron. Then, the 2 bottom bolts on the gear box need a 'round shim' ( I cut two out of 1/2 inch water pipe). Depending upon how far you move the box outward, the pitman arm and connector may hit the front wheel (mind does). Heating it up and bending it inward may be required.
I used the tubular motor-mount crossmember. Speedway motors has a set of exhaust manifolds that I used....their part # 930-0327 - $59.00 each (they are 2 1/2 inch Corvette style...similar to the 'ram horn').
penniwinkle is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Power steering conversion question...... omega7979 1947-1954 6 02-26-2011 10:54 PM
steering conversion LHD to RHD twobobbwana 1973-1987 3 09-01-2007 07:27 AM
Steering conversion guiness12pack 1960-1966 4 04-20-2004 09:22 AM
Power Steering Conversion on a '65 atagurl65 1960-1966 3 12-04-2003 08:48 AM
64 power steering conversion Danny4656 1960-1966 5 07-25-2003 11:54 PM
Powered by vBulletin® Version 3.8.9 Beta 4
