You could use the 79 front clip and bolt it in place on the 66. Scavenge the proportioning valve for the disc brakes and add a dual circuit master cylinder...it's almost a direct bolt in, I had to drill two holes, the rest lined up great. Then on to the power steering, REZ interprises makes a plate to bolt the late model truck box to the early frame, you will have to cut the straight steer shaft and add a late 'rag joint from the donor as well. There's more I know but that's the general oultline. Much easier without the fenders and engine but it can be done that way too. Ok, that's the front, for the rear try to find a 71-72 coil spring 5-lug differential and your good to go. I used the donor rear and cut off the leaf spring perches and welded the coil perches on, a bit of setup work with a degree wheel and tape measure, I ended up using the two-piece driveshaft, cut 2" off the end of it and welded the yoke back on...lucky me it doesn't vibrate~
I'll bet there are plenty of guys on this forum that'll be willing to pitch in with some more advice, so don't hesitate to ask. Good Luck!
