Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1967-1972
1967-1972 Discuss all aspects of your 1967-1972 Chevy or GMC Pickup
Reply
Old 04-26-2008, 01:01 PM   #1
fleetwood
Registered User
C10 - C20 Differances
Hi Y`all
Forgive me for asking a simple question - but I just bought a nice original 68 Chevy C20 with 396. What are the differances in a C10 and aC20?
fleetwood is offline   Reply With Quote
Old 05-02-2008, 06:37 PM   #2
TCain
Registered User
TCain's Avatar
it is the wieght they can carry its like the differance in a 1500 and a 2500 i think the c10 is a half ton while the c20 is a ton
__________________
67' C10
Fleetside
Wood Longbed
TCain is offline   Reply With Quote
Old 05-03-2008, 12:26 PM   #3
INGRAM1943
Registered User
A C-10 is a 1/2 ton truck with the wishbone/coil spring suspension in the rear. A C-20 is a 3/4 ton truck with leaf spring suspension in the rear. I think the 1 ton truck was a C-30??? The difference's are the payload capacities of each vehicle. Some other difference's may be gas tank size, saddle gas tanks, gas filler location(s) frame design & construction, shock absorbers and anything else related to weight bearing capability.
INGRAM1943 is offline   Reply With Quote
Old 06-16-2008, 03:22 PM   #4
Bad_Brad
Registered User
Bad_Brad's Avatar
They also had different axles....3/4 ton had 8 lugs and 1/2 ton had 6 lugs
__________________
Bad Brad
"If you can't find it grind it"
Bad_Brad is offline   Reply With Quote
Old 08-29-2008, 02:09 AM   #5
67Cowboy
Registered User
67Cowboy's Avatar
Exclamation C10 Chevy 1/2, C1500 GMC, C20 Chevy 3/4ton C2500 GMC
C20 or C2500 are made a little heavier duty than the 1/2 ton: Heavier ball joints, tie rod ends, springs, and they have greaseable bronze bushings in the A-frame while the 1/2ton use rubber a-frame bushings. Also C20 uses the 1350 heavy u-joints apposed to the 1310 smaller joint in 1/2 ton. The C20 rear axle is the HO72 (Big Pumpkin), like the front it has bigger bearings, shafts, tubes and gears over the little 8.5 10bolt or 8.75 12 bolt in the 1/2ton. All design to be a heavier duty 8 lug truck made to haul quite a bit more weight than the lighter weight 1/2 ton made for economy.
Most of the other differences have to do with the package ; CUSTOM, CUSTOM DELUXE, CHEYENNE, CHEYENNE SUPER, CST, SIERRA, SIERRA GRANDE, CUSTOM CAMPER, SUPER CUSTOM, LONG HORN ETC...
My '67 C20 came factory with coils spring rear suspension but most 3/4ton trucks like my '69 Custom Camper Camper came with leaf springs, and it was the 1/2 tons that came with leaf.
67Cowboy is offline   Reply With Quote
Old 08-31-2008, 11:31 PM   #6
sweet70beast
Registered User
sweet70beast's Avatar
Weather it's a 1/2 ton or a 3/4 ton doesn't really matter as far as what springs it came with. It matters how they were ordered and if Chevy or GMC.
On Chevys coil springs were standard and leafs were optional. On GMCs leafs were standard and coils were optional. I have seen 1/2 and 3/4 tons both ways.
__________________
1947 Chevy Panel
1950 Chevy 3100
1950 GMC
1953 GMC Suburban
1954 Chevy Suburban
1970 Nova 327/T5
1971 K-20 350/TH350/205
1972 Skylark (Suncoupe)
1 of 3943 made
1976 Chev C-10 350/350
sweet70beast is offline   Reply With Quote
Old 12-20-2009, 02:24 PM   #7
capev86
Registered User
yeah....the 3/4 tons basically got heavier duty versions of the 1/2 ton parts....especailly at the rear. 1/2 ton rear springs are not rugged enough for hauling loads in my honest opinion. the 3/4 tons with rear coils have thickened trailing arms and the panhard bar is way thicker with bigger ends....a definite plus that i like about my 72 suburban 3/4 ton. the one tons were the only trucks that got leaf springs on the rear exclusively. but you can get 3/4 ton HD option coils for the back that give a 3/4 ton the weight capacity of a 1 ton.....the axles and frames are heavy duty enough. 1/2 tons got the 12 bolt rear end. '72 and older 3/4 ton trucks came standard with the HO52 corporate/eaton rear axle that came with a 4.10 or 4.57 gear (higher ratios also exist. an aftermarket 3.90 gear was available but is no longer produced. the HO52 and its big brother the HO72 (1 ton) had a removable third member like a ford 9 inch and bolt in full floating axles like on the 14 bolt full floater axle that followed. the HO72 had a pinion preload bolt and only was used on leaf springs. you could do a retrofit to a coil spring truck by welding the panhard bar mount and trailing arm perches to axle....but the 52 is plenty stout. there was also a dana 60 on the 3/4 ton trucks with big blocks (3.50-something gears). the corporate axle has a prettier looking diff housing though and is something of a rarety now as many offroaders run the dana axles because they are more modern and parts are more prevalent. you can still get the seals, gaskets,etc new if you do some searching and can live with the fact that most auto parts people out there won't have an clue about the axle you have. the HO52 is often mistaken for an HO72 because they are essentially the same axle. ok....thats already too much rambling......
capev86 is offline   Reply With Quote
Old 12-20-2009, 02:38 PM   #8
capev86
Registered User
2wd suburbans (like my truck) came standard with the 4.57 geared HO52 and never got the 4.10 gear from the factory, unlike pickups and 4 wheel drive burbs with automatis, so i am switching the third member over from a donor pickup. will be running royal purple synthetic gear oil.....'cause any rear end works better with some tlc.
if your 2wd truck didn't come with a front sway bar, i hear through the grape vine you can swipe one from the next generation truck. 1 tons and camper specials reportedly got 1-1/4 inch sway bars (1-1/8" was standard and even smaller on the 67-72). the front chassis was carried over into the next generation but GM ditched the fancy trailing arm rear end in favor of cheaper/simpler leaf springs. the trailing arm suspension is good but its a good idea to replace the worn out old rubber bushings on the trailing arms and panhard bar with poly to eliminate slop in the rear suspension. remember that 3/4 ton trucks use the same bushings for the trailing arm, but larger bushings on that beefy track bar.....i have them in poly alreadyu installed on my burb but most suppliers only sell the 1/2 ton variety in poly.....as always, research is key.
Old 12-31-2009, 01:21 PM   #9
I_FLY_LOW
Registered User
Is there much difference in the outside appearances of the c10 and c20?
Are their parts interchangeable?
Can you easily upgrade a c10 to a c20, or are the chassis' different?
I_FLY_LOW is offline   Reply With Quote
Old 01-01-2010, 04:27 AM   #10
2tons of fun
Registered User
2tons of fun's Avatar
chassis are the same for the most part, the steel maybe a bit thicker.
the trailing arms are plated in a 3/4 and not in a 1/2
you could get 1/2 and 3/4 with coils or leafs. you could also get a half leaf helper spring but idk if it was 3/4 only.
a 3/4 would have a ho52 or a d60ff, [rare 1/2s had a d60 sf 6lug]
from the out side the only difference is the lug count and the ff rear hub.
with a bbc the front coils will have some extra load to them too.
there are minor difference like the lower a arm is slightly different as is the spindle/knuckle, but they can be made to inter change.
2tons of fun is offline   Reply With Quote
Old 03-22-2011, 11:58 PM   #11
aggiejon
Registered User
Does anyone have a HO72 with a 4.10 gearset they would like to be rid of?
__________________
We're blogging about the restoration:
http://jons49chevyresto.blogspot.com/
Pictures hosted at Photobucket:
http://s422.photobucket.com/home/jongersbach
aggiejon is offline   Reply With Quote
Old 06-06-2011, 01:36 PM   #12
ChevyMitch
Registered User
Hay, if anyone can help?
Please look at my over-load "updated" over-load spring thread, as it has more info.
Thanks
ChevyMitch is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Frame for 54 3100 54 Mississippi 1947-1954 20 03-31-2007 07:51 AM
Powered by vBulletin® Version 3.8.9 Beta 4
