Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1955-1959
1955-1959 Discuss all aspects of your 1955-1959 Chevy or GMC Pickup
Reply
Old 07-29-2004, 03:09 PM   #1
road_king
Registered User
Post How to remove hub from brake drum
Hellow All,
I'm working on rebuilding my front-end. I have just installed new leaf springs and have cleaned/painted the front axle. I have also removed the king pins and bushings and the spindles are ready to be cleaned and painted, and I have new bushings and king pins in hand.
Along with the above, the plan is to replace the brake parts and use new tapered bearings (also in hand). I will be reusing the backing plates - which have already been cleaned and painted.
So, I have purchased new brake drums and after removing the bearings and mounting bolts from the old hub, I can't figure out how to get it the rest of the way off to install in the new drums. I see that there are 3 permanent "knobs" that protrude through the drum, but after a couple of strikes with a hammer, they started to get disfigured.
What am I missing? I can't find any reference to this in the "factory assembly guide" or the "shop manual". My secret technique of "beating the hell out of it" isn't working this time!
Thanks in advance,
Tim Bleeker
58 Apache 3100
See the project journal at http://www.road-king.com/58chevy
road_king is offline   Reply With Quote
Old 07-29-2004, 03:28 PM   #2
tech1
Registered User
tech1's Avatar
RE: How to remove hub from brake dr
you may have to have them pressed out if you cant knock them out:+
tech1 is offline   Reply With Quote
Old 07-30-2004, 01:57 PM   #3
DrMike
Registered User
DrMike's Avatar
Try loosening the adjuster on the brakes. Your shoes may be tight against the drums, not letting you remove it. Hitting it with a hammer may still be necessary to loosen it once you have backed off the adjuster.
Mike
__________________
'58 Stepside
305 engine and 350 tranny
DrMike is offline   Reply With Quote
Old 07-30-2004, 02:37 PM   #4
Bill Hanlon
Registered User
Bill Hanlon's Avatar
Those '3 permanent "knobs" that protrude through the drum' are actually large rivets. To remove the hub grind off or drill through the head of the rivet, then use a punch and a hammer to drive the remaining piece through the hub and brake drum. The drum may still stick to the hub because of 45+ years of intimate contact. If so, revert to your "beating the hell out of it" procedure. It is not necessary to put in new rivets. I ran my daily driver for 10 years after putting new drums on the front without replacing the rivets. And another 5 years now with disk rotors attached to the hubs in place of the drums.
__________________
Bill Hanlon is offline   Reply With Quote
Old 08-02-2004, 11:24 AM   #5
road_king
Registered User
Thanks for the help everyone, especially Bill - I like answers that involve my hammer!
Tim B.
Old 09-05-2004, 06:31 PM   #6
Halfton57
Registered User
I used an air hammer along with with my compressor to make quick work of the rivets. The rivets aren't necessary when you reassemble the hub/drum assembly.
Stepside57 in the Central San Joaquin Valley of California
__________________
Halfton57 is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Drum brake problems mittleiderj 1960-1966 1 11-09-2005 06:47 PM
brake drum rivets johnnybee 1955-1959 3 01-03-2005 07:36 PM
Rear brake drum removal apachesb61 1960-1966 2 11-07-2004 08:16 AM
Power Brake Setups? grayhitandmiss 1960-1966 0 03-14-2004 07:52 PM
rear brake drum froze rustbucket 1960-1966 2 01-27-2003 04:20 AM
Powered by vBulletin® Version 3.8.9
