Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1960-1966
1960-1966 Discuss all aspects of your 1960-1966 Chevy or GMC Pickup
Reply
Old 10-30-2008, 08:40 AM   #1
Thunder65
Registered User
Wiper switch
I had recently bought a Wiper switch from Classic Parts. It has three prongs running out the back. The original 1965 switch has on single prong coming out the back. The painless kit has one wire that fit the orginal switch. Does anyone know how to run the wiring from the new switch. I'm not sure how the three prongs on the back on the new switch are to be connected( I understand the new switch is a two speed w/washer). The current Wiper moter looks like it only has two prongs comming out. I believe a pink and a white wire are currently connected to the motor from the Painless Kit. I will probally end up replaceing the wiper motor with one from Classic Parts that has three prongs. I'm doing further testing to see, but if I keep the old one how should it be connect. Any help would be appreciated this is the only wiring issue I have left and the truck is DONE knock on wood.
Thunder65 is offline   Reply With Quote
Old 10-30-2008, 10:55 AM   #2
283 man
Registered User
283 man's Avatar
Send a message via MSN to 283 man
Arrow
Call Customer service at 1-800-741-1678 they will help you out with your problem.
283 man is offline   Reply With Quote
Old 10-31-2008, 08:30 AM   #3
Vin63
Registered User
Vin63's Avatar
Yep, I'm pretty sure you got it right...two-speed switch with a windshield washer function. For my '63, I have a two-speed wiper switch with the center push button for the washer and it is a three-prong connection.
__________________
1963 C-10: custom cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. cyl. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front and 4-piston rear disc brakes
Vin63 is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
wiper wiring 78moneypit 1973-1987 1 06-23-2008 07:33 AM
wiper switch mark64 1960-1966 4 11-09-2005 07:26 PM
Intermittent Wiper Switch Dollylock 1973-1987 6 09-05-2004 10:05 PM
wiper switch 3dogsmith 1960-1966 1 08-21-2003 07:14 AM
windshield wiper switch krumby 1960-1966 0 10-25-2001 09:53 AM
Powered by vBulletin® Version 3.8.9 Beta 4
