Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1955-1959
1955-1959 Discuss all aspects of your 1955-1959 Chevy or GMC Pickup
Reply
Old 10-15-2005, 08:55 PM   #1
DrMike
Registered User
DrMike's Avatar
Wiring an HEI distributor
Just finished my new engine install and a new ChevyDuty wire harness. Can't figure out how to wire up the HEI distributor.
ChevyDuty techs can't help with any advise at all. The wiring diagrams supplied with the harness don't give you an HEI option.
Anyone out there had this problem? How did you solve it? Any help would be appreciated. Want to get Baby Blue back on the road.
Dr. Mike
__________________
'58 Stepside
305 engine and 350 tranny
DrMike is offline   Reply With Quote
Old 10-16-2005, 06:47 PM   #2
Bill Hanlon
Registered User
Bill Hanlon's Avatar
RE: Wiring an HEI distributor
I put an HEI in my '57 GMC V8 years ago. Easy to do and works well.
Assuming it is an early HEI (pre-computer with only two connections) one connection is tach output and the other is +12V. Looking down from the top the tach connection is clockwise from the +12V connection. The 12V feed needs to be fairly hefty. I ran mine through 10 gauge wire. You have to eliminate the "ballast resistor" from the circuit. The easiest way to do it (and the way I did mine) is to find a connection on the back side of the ignition switch that has 12V when the key is in the "start" AND in the "run" position. Make up a 12 gauge wire with an in-line 20 amp fuse. Connect that wire from the ignition switch directly to the BAT position on the HEI. You do not have to connect anything to the TACH position, but if you want a tach, most semi-modern tachs (like my Sun Super Tach III) work just fine when connected to the TACH output. Ive attached a page that I found somewhere about troubleshooting HEIs. Note that the picture of the cap is from the INSIDE so the TACH and BAT connectors are reversed.
One more tip. An HEI is a reliable source of good spark, however when it dies, it dies in a hurry, not slowly like points-based ignition. I now (after a $65 tow charge in the middle of the night) keep a spare module (less that $20), a 1/4" nut driver and a flat blade screwdriver under the seat.
http://talk.classicparts.com/images/...a606dc494a.jpg
__________________
Bill Hanlon is online now   Reply With Quote
Old 10-25-2005, 07:29 PM   #3
Halfton57
Registered User
I put an HEI distributor in my "57 350/350 several years ago and have been very pleased with the results.
Stepside57 in the Central San Joaquin Valley of California
__________________
Halfton57 is offline   Reply With Quote
Old 01-01-2006, 08:19 PM   #4
chevymantrucks
Registered User
chevymantrucks's Avatar
Bill you the man on this one!!:-)
chevymantrucks is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Very puzzling-STOCK DISTRIBUTOR WON'T FIT The Pack Rat Performance, Engine, and Transmission 3 01-13-2008 09:57 AM
Distributor problem put-put 1947-1954 25 11-08-2007 01:49 PM
Distributor - Embarrassed to Ask ltcmikem 1947-1954 10 04-17-2006 08:03 AM
Woohoo! Wiring is done! volcan96 1947-1954 1 12-30-2005 08:41 AM
Ignition Wiring DrMike General Chevy & GMC Pickups Talk 2 05-21-2005 06:48 PM
Powered by vBulletin® Version 3.8.9 Beta 4
