Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1960-1966
1960-1966 Discuss all aspects of your 1960-1966 Chevy or GMC Pickup
Reply
Old 01-06-2009, 07:02 PM   #1
rustbucket
Registered User
Transmission hump
i go from engine issues to a desperate call for help!!
My pillaged '62 cab had a stick shift and whats going in is on the tree so I need to replace the transmission hump panel. I thought the 63 hump panel would fit, but NO... it is a big hump and the '62 is small.
Does ANYONE have, or make, the center (transmission hump) panel for a '62?
Does anyone make the ENTIRE floor panel?
rustbucket is offline   Reply With Quote
Old 01-08-2009, 02:18 AM   #2
dcsi5919
Registered User
dcsi5919's Avatar
No, the entire floor panel or the tranny hump cover are not currently being reproduced. You can get partial floor patch panels, as well as lower kick panels from this site sponsor, Classic Parts.
FYI, all factory floor shift trucks (SM420 or SM465 4-speeds) came from the factory with a high hump tranny cover. If you have a low hump, your truck was originally equipped with a column shift auto or manual, so it must have been modified somewhere during its history.
__________________
LILRD66 ('66 C10)
BCKNBLK ('66 K10)
OLRUSTY ('65 C10)
OLRED66 ('66 C20)
BIGBLUE ('66 K20)
dcsi5919 is offline   Reply With Quote
Old 01-08-2009, 11:02 AM   #3
drabo
Registered User
drabo's Avatar
Can you cut the hump out of your old cab?
__________________
66 Chevy C10 "The Nugget" 283/700R4
drabo is offline   Reply With Quote
Old 01-08-2009, 01:18 PM   #4
beck
Registered User
Doesn't the hump panel just bolt in?
I changed the floor confituration on my truck quite a bit. When I was doing this I thought the hump panel just bolted in. If so that allows it to be changed from a big hump to a small hump or the other way around. If you run the big hump anything stock under the floor will work. So just put a big hump in and whatever you do down the road will be fine as far as the floor is concerned.
My 62 truck may have been converted somewhere along the line but it had an automatic column with a single pedal. The hump was a big one. I think the big trucks (ones with side steps) had little humps. Those cabs were installed higher on the frames so the big hump wasn't necessary to clear the transmissions. They did have holes in the humps for the shifter and brake levers. These trucks should be available for parts if you are in a rural area. Find one that was barn kept and the cab and floor will be in good shape.
My floor is really different. I had to move the hump higher and slightly to the left. The right front of the hump at the firewall had to have a bubble added. Why you ask? My motor was intentionally offset to the drivers side and the truck cab is lowered on the frame so the hump had to move up and left to clear the 475 turbo trans (thats a 400 with stronger straight cut gears). The bubble in the right front of the hump was to clear the 3" discharge coming from the turbocharger mounted on the Cummins diesel exhaust manifold. I'm buildin' a slammed smoker.
beck is offline   Reply With Quote
Old 01-08-2009, 02:03 PM   #5
dvalentine
Charter Member
dvalentine's Avatar
Only the Big hump has a bolt-on inspection cover Buddy.
Val
__________________
1964 C10 Panel 350 HO Crate and 700R4
1937 Ford Cabriolet ZZ4 & Tremic 5 speed
dvalentine is offline   Reply With Quote
Old 01-09-2009, 07:20 PM   #6
MOJO1963GMC
Registered User
Quote:
Val
My '63 GMC has a small hump tran cover that is bolt on...Or are you talking about the '64-'66's Chev/GMC? I've noticed that all the ones I see that are small hump are in one piece and are permanetly attached to the cab.
MOJO1963GMC is offline   Reply With Quote
Old 01-10-2009, 12:09 PM   #7
dvalentine
Charter Member
dvalentine's Avatar
Quote:
Yup I was... Sorry... 64-66 3 speed column shift and automatics have solid pan floors including the trans hump. The 4 speed models and the 4 wheel drives have the high hump...
Val
__________________
Old 01-12-2009, 08:44 PM   #8
rustbucket
Registered User
wooohooooo
it fits...just took some finesse....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
transmission and diff gear oil cochran 1947-1954 4 10-28-2008 02:34 PM
Which transmission with a 216 Volker 1947-1954 14 11-01-2007 06:53 PM
Junk transmission, high price overhaul KentC 1947-1954 30 09-19-2006 12:29 PM
Transmission Hump Ebon Hawk 1960-1966 2 03-07-2006 08:20 AM
Turbo 350 Transmission Leak 1964swb General Chevy & GMC Pickups Talk 3 06-08-2004 09:34 PM
Powered by vBulletin® Version 3.8.9
