Classic Parts Talk
Go Back   Classic Parts Talk > Chevy & GMC Trucks by Year > 1960-1966
1960-1966 Discuss all aspects of your 1960-1966 Chevy or GMC Pickup
Reply
Old 01-31-2009, 11:22 AM   #1
raking
Registered User
raking's Avatar
700r4 conversion
I have a 1965 C10 swb truck. I would like better fuel economy from the 1972 350 with 350 turbo from a 1972 Monte Carlo(3.43 rear end). I have been exploring 700r4 trannys,aftermarket overdrives and 3.08 rear gears. any suggestions as the best way to go. the truck is used for cruising and not a lot of towing. While driving down the highway it seems I need another gear. Thanks for your input. raking
raking is offline   Reply With Quote
Old 01-31-2009, 03:13 PM   #2
dvalentine
Charter Member
dvalentine's Avatar
The 700 R4 is the way to go ! I used 373 rear ratio and still averaged 19 mpg with a PANEL TRUCK !! Freeway milage was 21-22 mpg.
The 373 ratio allows better "feel" on surface street driving, good launch and normal shift ranges. 308 ratio rear may make it feel sluggish for street surface driving causing you to step into the throttle more, which is what you don't want for milage purposes.
Val
__________________
1964 C10 Panel 350 HO Crate and 700R4
1937 Ford Cabriolet ZZ4 & Tremic 5 speed
dvalentine is offline   Reply With Quote
Old 01-31-2009, 05:06 PM   #3
raking
Registered User
raking's Avatar
Thanks a lot. I'm glad I found this forum. Is the TV difficult to adjust? How do you think the 3.43 will perform?
Old 01-31-2009, 05:31 PM   #4
dvalentine
Charter Member
dvalentine's Avatar
Quote:
In a word ?? YES..
but only if you want it done correctly so the trans does'nt melt down in the first few miles of operation !!!
I had mine adjusted by a trans shop after I installed it, and took it there on a flatbed.
Read TV101 on this site: http://www.700r4.com
343 will be better than 308's in my opinion...
Val
__________________
Old 02-01-2009, 12:58 AM   #5
Pontiac1976
Registered User
Pontiac1976's Avatar
Send a message via ICQ to Pontiac1976 Send a message via AIM to Pontiac1976 Send a message via MSN to Pontiac1976 Send a message via Yahoo to Pontiac1976
I heard some Pontiac guys useing 3.23 gear with the 700R4 but there lighter then a truck for the cars you would not want to go lower then that with a car.
I beleave 3.43 or right around that is the lowest gear for the 700R4 to work best not hurt gas milage. In a truck
__________________
77GMC 1/2 ton Pu 454 has been my daily driver since 98-04, other than oil changes tune up. I put new fuel pump timing on the motor. UP date front clip to 84 clip an 89van F bumper was put on. I took out the 454 to try to save on fuel. I put 85 305 SS motor, still using the 77 3core rad. I had to do work to the right brace for the bumper and drill new holes, on the bumper. I had to make new top braces to hold the top of the rad. It's a flatbed homemade steel bed all this. Make a great work bench
Pontiac1976 is offline   Reply With Quote
Old 02-02-2009, 09:44 AM   #6
drabo
Registered User
drabo's Avatar
You will see a huge diffrence with a 700R4 swap. A couple things to keep in mind the driveshaft needs to be shortened. You will need a TV corrector bracket if using an aftermarket carb. An additional tranny coler is a must even if you have a automatic radiator. Also need a new mount and tranny crossmember www.classicperform.com . www.bowtieoverdrives.com is a good source for ideas on what you need. Shop around for your parts BTO is pricey. BTO also has a good speedo calculator for getting the right speedo gears.
__________________
66 Chevy C10 "The Nugget" 283/700R4
drabo is offline   Reply With Quote
Old 02-02-2009, 06:13 PM   #7
raking
Registered User
raking's Avatar
i'm currently using the original quadrajet carb but thought in the future I might go with an edelbrock carb to se if performance and mileage improve. Anyone use this? if so does it really help to get the intake carb combo or does the stock intake work just as well?
Old 02-03-2009, 07:37 PM   #8
verdell
Registered User
Cool
I'm running a stock 350 w/ 700r4 and 3:08 rear....changed over to a edelbrock carb and intake..there was a noticable difference in performance..btw switched over to an electric fan which helped also..
verdell is offline   Reply With Quote
Old 02-03-2009, 10:27 PM   #9
Rich 5150 69
Registered User
Rich 5150 69's Avatar
Note if using the rear motor mount holes, so that the distributor is close to the fire wall, you`ll have tranny / body interference at the seam that is on the lower portion of the firewall, some trimming may be necessary.
__________________
`64 short box
Rich 5150 69 is offline   Reply With Quote
Old 02-04-2009, 01:28 PM   #10
drabo
Registered User
drabo's Avatar
Quote:
I used a body pannel adjustment tool (hammer) to correct this problem.
Aslo I am using the performer/performer combo. There was a big diffrence. I am getting a more complete burn and less black soot.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Power steering conversion question...... omega7979 1947-1954 6 02-26-2011 10:54 PM
V8 Conversion Scooter1955 1955-1959 2 01-02-2007 08:08 PM
700r4 computer jason6101188 1947-1954 3 11-22-2006 07:51 AM
Power brakes conversion shelby987 1955-1959 3 12-12-2004 08:46 AM
Vortec conversion 73 blazer mongo General Chevy & GMC Pickups Talk 1 02-17-2002 10:52 PM
Powered by vBulletin® Version 3.8.9 Beta 4
