I apologize for this long-winded post. Those of you who aren't big readers you can get the "cliff notes" version by starting at the pictures
So I've had this truck for about 3 weeks now and I've basically in the beginning stages of my interior fix up. All of the wiring and gauge cluster has been removed, and today I began removing what's left of the floorboard upholstery. The firewall pad has all but disintegrated so I started with getting all that off. I'm not too sure about the floorboards, there was some type of rubber matting glued to the floor. Anyhow I got about 95% of this rubber matting off the driver's side floor and was greeted with this:
Enlarge
Enlarge
Enlarge
Some questions (of course) do arise as far as the repairing process:
Can this possibly be all fixed with patch panels and if so which ones do I need? I'm assuming an inner rocker panel but besides that I'm not too sure. I have the equipment to cut and weld in new panels however I am *very* hesitant to just go hacking away.
Is utilizing some flavor of rust converter and encapsulator sufficient for this type of repair? I have an 80s camaro that we repaired by cutting most of the rust away, then using eastwood's rust converter/encapsulator combo followed by fiberglass matting on the backside and body filler on the front, is this an option?
My main concern is to stop and repair the rust versus making the repair look awesome. This something that will be covered by sound deadener, heat shield, and carpet. Any suggestions would be awesome.
Enlarge
Enlarge
Enlarge
