power windows
Discussion in '1960-1966' started by Dougs55, Feb 15, 2014.
  1. Dougs55
    Dougs55 Member
    Anyone had any luck with the universal power window kits? I tried installing a set in my 64 and they are not working the way they should. If you mount them outside the door panel then there isn't enough room to put the door panel on. If you try moving it to the inside of the door then it binds up and doesn't want to run the window up and down smoothly. The installation instructions are crappie and are of no help. Am I doing something wrong with where I am trying to mount the motor?
  2. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
  3. Dougs55
    Dougs55 Member
    Thanks Rich but mine are obviously the cheezy ones as they were supposed to work off of the existing windor crank. Guess I through that money away and will have to spend the $450 to get the right ones.
    These people shouldn't advertise something that won't work. As the old saying goes, "You get what you pay for".
    :mad:
