Installing a C-Notch
Discussion in '1947-1954' started by Ricos54, Jan 7, 2014.
  1. 50 Chevy LS3
    50 Chevy LS3 Member
    Indiana
    You are right, Rico, the floor is 16ga. The "rockers" are somewhere between 18-19ga.
    Wish I could get along with the speed you are.
  2. Ricos54
    Ricos54 Member
    CA
    Yo 50, would putting the 3/16" flat bar underneath the cab do the trick? Want to make sure about support and don't want to have problems later since this will be my daily drive.
  3. 50 Chevy LS3
    50 Chevy LS3 Member
    Indiana
    Rico, I would probably use some sort of "C" channel. Flat stock would not stiffen up the 16ga. enough IMO. The bolts that attach the "shackle type" rear cab mounts go through the mount itself, the floor support, the floor sheet, the missing C channel (rear seat riser), and finally a thick threaded flat nut plate. You could possibly make a inverted "hat" shaped channel span from existing rear floor support to floor support. Anything additional on the top side would help, to tie the latch pillars together. Also, I would plug weld some angle steel across the underside of the cab to match the forward mounting points of the seats. Any movement of the seat or cab at these points will eventually result in fatigue cracks.
    Seat belts are really serious, because the weight of a human occupant multiplies many times in the event of an accident. G-forces can multiply 15-20 times in really severe collisions. The modern auto manufacturers use large heavy washers or nut plates placed behind door pillars or doublers in the floor sheet to anchor seat belts.
    The "C" channel or angle you use does not have to be real heavy, it could be formed 16ga. like the floor and plug-welded in from the top.
  4. ol' chebby
    I like to run a thick flat stock under the floor and bolt all seatbelts through that with grade 8 bolts, big washers and nylock nuts.
  5. Zig
    A future project. Thanks for the info. :cool:
    Wow
    As always , much detail and forward thinking going on here , I love reading these buildups .
    The little I know of support leads me to think the round cross support will be strongest .
  7. Ricos54
    Ricos54 Member
    CA
    Just finished capping off the back of the bed and filling the post holes, Also since I'm raising the bed floor I didn't want to have some piece of wood holding the bed up so I built these little risers to make up the difference for the square wood blocks and the 3/4" wood floor.
  8. Ricos54
    Ricos54 Member
    CA
  9. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Rico,
    You ever thought about moving the roll pan forward and making it tie across the rear fenders? I did that on my '65... just curious if you'd considered it?
    John
    Bed Modifications
    Wow ~
    That bed is going to look smooth as a baby's bottom when you're done ! .
    I look at it and wonder : ' yabbutt , where do you tie the ropes & hook the tie down ratchets ? ' :rolleyes: .
    I hope to never had a truck I don't want to work out of no matter how nice and clean it is .
    Keep up the GREAT works Rico ! .
  11. Ricos54
    Ricos54 Member
    CA
    Thank you Nate, what my plan is to put tie downs in 6 different places in the bed so I can still haul stuff if need be :D
  12. Ricos54
    Ricos54 Member
    CA
    Roadster, my plan is to install a tow hitch right behind the license plate so I need all the room for,that so I have to keep the roll pan where it is.
  13. Zig
    Keep rollin right along there, Rico~ Your ride is really coming together!
  14. Ricos54
    Ricos54 Member
    CA
    Started raising my bed floor toady and also bought the front panel for my bed
  15. ol' chebby
    That will work. Put a few cross bars to support the floor.
  16. Ricos54
    Ricos54 Member
    CA
    I was going to build another box on top of that one in 1" x 1" and put cross bars in that one because that's the one I will have as the tilt bed so do you still think I'll need those cross bars on the first one?
  17. ol' chebby
    No, probably not. Make shure to leave enough space at the front for hinges.
  18. Ricos54
    Ricos54 Member
    CA
    Welded up my frame today glad I got that out of the way. Lol
  19. SinclairChevy
    SinclairChevy Member
    Keokuk, Iowa
    Lovin' this thread, Rico!!!
    Damon
  20. ccharr
    I really am enjoying following this thread Rico, Thanks for up dating so often. Glad to see the owners able to do there own work.
