V8 conversion motor mounts
Discussion in '1955-1959' started by smfulle, Jun 8, 2009.
  1. smfulle
    smfulle Member
    Ogden, Utah
    Can anyone tell me if they have used the V8 conversion motor mounts sold by our host, part # 79-375? How do they work? Do you have to drill holes in the cross member to bolt them to? My truck, a 59, has a 327 installed by the previous owner where a 6 cylindar used to be, but he did kind of a wack job on it, welding in some random crossmember then putting some home made front motor mounts on it. I am putting in a new 350 and am trying to fix the thing right as I go. I am trying to stick with the original front motor mounts because I have the standard transmission and want to stay with the rear bell housing mounts.
    If anyone had pictures of these mounts installed I would love to see how they fit and how they work.
    Thanks,
    Stan
  2. azcarman411
    azcarman411 Member
    Rimrock, Az
    Those mounts are what your truck would have if it came from the factory with a V8. I havent used the repop set your refering to, but they look alot like the factory ones, and those work well. The only time you cant use the front mounts is if you running a automatic or power steering. The holes are already there in your front crossmember, just bolt em in! Chris
  3. smfulle
    smfulle Member
    Ogden, Utah
    Thanks Chris,
    I guess I'll get them and give it a try.
  4. lonehorn57
    lonehorn57 Member
    Dupree, SD
    motor mount conversion
    stan,
    I put them on my 57 Chev, they fit real well and bolt right to the front of the 1966 283 c.i. that I am using. I bought grade-8 bolts to use and have never had any trouble. The necessary holes are already in the frame.
    jim
  5. RaymondSherwood
    RaymondSherwood Member
    smfulle is your truck a Chevy or GMC? How did they work?
    You see I'm in the same boat. I replaced the 270 straight 6 with a 350 back in 1997, my father and I built a motor mount from 1/4 steel off the straight 6 mount; and now the mount is starting to finally weaken and now I'm much older and want to do it correctly.
    I ask if yours is a Chevy or GMC is because the cross member on the GMC is slightly more forward.
    I can't decide to use Part # 79-375 or Part # 79-405
  6. steve
    steve Member
    Virginia
    Different Type
    I used this type and seems to work well so far.
  7. smfulle
    smfulle Member
    Ogden, Utah
    My mounts
    Raymond,
    My truck is a Chevy. Sorry, I haven't been on the forum in a while and just saw your question.
    The mounts work great on my 59 in combination with stock bell housing mounts in the rear.
    You should be able to see the mounts in the picture.
  8. coilover
    Raymond,
    You used the wrong 350, the GMC's came with Pontiac engines in the V8 model. No worry though as there are mounts available from Chassis Engineering and others. One can have power steering and automatic also. The pump is on the back of the generator or use Alan Grove short waterpump mounts. The cast iron Powerglide mounted to the crossmember and there also are mounts to bolt from crossmember to modern transmissions. We just finished a 55 with front motor mounts, p/s, and a 200R4 overdrive automatic.
  9. coilover
    Actually that should be 2004R, the 700 is R4.
  10. VELCRO
    VELCRO Member
    OCALA USA
    Headers
    smfulle
    I have a question for you. The headers on your truck, what brand are they and do you have a part number for them? The headers I used make changing some of the spark plugs almost impossible, it looks like it would be easier to get to your plugs. Are you using the original steering box and do they clear it ok?
    That's a clean looking engine you have.
    Gerald in Ocala, Fla.
  11. Beamer
    Beamer Member
    Ontario, Canada
    Hey Steve. I like the looks of the mounts you used. Did they work out ok? Where can I find them? Thanks!
  12. steve
    steve Member
    Virginia
    Not Bad
    Beamer,
    I had them for about five years, (part number 7204771), make sure your engine selection allows the three bolt connection the newer block, mine is a 1972 block.
    I like the fact that nothing runs under the engine, they are real solid construction, bolting to the side of the block ties everything in. all hardware is provided. approximately 90 bucks. it allows you to move the engine forward like I did, or back where you need it. I wanted to clear the fire wall and if I used the under engine tube type it would have interfered with the straight axle when the leafs compressed.
    Moving the engine forward, I also needed a custom drive shalt, no dig deal. You could add additional flat stock inside the frame if you wanted more support, my 300 hp is fine like it is.
    http://www.speedwaymotors.com/Search?query=1959+truck+motor+mounts
  13. Beamer
    Beamer Member
    Ontario, Canada
    Thanks Steve!
    We may beef up the inside a little but would prefer not to add another cross member.
    Moving the engine forward a little will be a benefit as we are hoping to use a manual transmission while keeping the bench seat which may pose a problem...
    No drive shaft with the truck... bought as a rolling chassis with separate 350 sb so we can address the drive shaft later
    Thanks again for the help.
    Beamer (and son )
  14. smfulle
    smfulle Member
    Ogden, Utah
    headers
    58Apache,
    Sorry i haven't replied soon about my headers. I haven't been on here much lately.
    My headers are Headman Elite Heavy Duty, part #69268.
    I got mine from Summit Racing.
    http://www.summitracing.com/parts/hed-69268
  15. VELCRO
    VELCRO Member
    OCALA USA
    headers
    Thanx for the info
  16. Arthur/K
    Arthur/K Member
    Original V-8motor mounts
    I am planning to use the original V-8 motor mounts 79-375 on 59 3100 . I am putting in a 283 from a 1964 that does have the front holes in the block. I am also replacing the 4 speed with a Power Glide is that going to be a problem? and do I need to install the transmission crossmember?
    Thanks for any help
  17. mikebte
    mikebte Member
    Wyoming
    I used this same mount in my swap. I made a video, but it only shows the mounts a few times.
    http://youtu.be/qbxkKAPI6jQ
    I'll get more info on them asap
