Fuel filler neck
Discussion in '1947-1954' started by coilover, Mar 21, 2014.
  1. coilover
    Here's the way we have been doing most of the fillers for the fuel tanks moved out of the cab. This is an S10 tank with a filler tube from exhaust tubing that has been expanded to fit the tank neck diameter on one end and matches the threaded bung size on the other end. A short piece of fuel hose joins the tube to the tank and to the bung. The cap screws in till tight and then is pushed down and turned a quarter turn so it's flush with the surrounding panel. The caps were used on motorcyle tanks and the cap/bung assembly is offered by several venders. When painted the same color as the panel it's in it is nearly invisable. Pictures with cap in LR of a 52 fender and try to find it on the blue car---about halfway between top of license plate and tail light. Zoom in.
  2. ccharr
    Thanks Even, that is great the way it is done.
    I never cease to be amazed at how the Hot Rodders keep coming up with these neat details .
    Good work there Evan ! .
    If I had to drive a Brand 'F' (shudder) it's be the one on the right......
    Yes , push 'n pray brakes and all .
  4. Zig
    That's a thing of beauty there, Evan! I assume it has a seal to keep water out? I'm sure that sparked some ideas~ I know it did me. ;)
