Ballist resistor .. Do I need one.
Discussion in '1947-1954' started by 2rods, Apr 4, 2014.
  1. 2rods
    2rods Member
    Darwin NT
    My Aussie 1950 truck is killing points..
    Do they need a risistor fitted to the coil?? It's 12 volt
  2. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Ballasted Ignition
    No ! only is the coil is 1.6 ohms measured across the small connections and then only if you have a solenoid operated starter with a by pass circuit wired in .
    I'm surprised at John's answer here .
  4. Lakeroadster
    Lakeroadster Member
    Central Colorado
    So now I am confused Nate??? Not trying to hijack 2rods thread, just trying to understand.
    My '65 C10 with a 350 V8, Accel Super Coil and points ignition has a ballast resistor (all was on it when I bought it)? Maybe it shouldn't have a ballast resistor? Help me out Nate, should I diagnose it by following the data below that this really knowledgeable guy stated on 02-26-2012?
    Just So ~
    *IF* you're running 12 volts .
    *IF* you have a bypass circuit
    *IF* the hot wire at the coil only gets 7 ~ 9 volts DC when they key is on ,
    Then a resisted system is correct .
    GM's and Brand 'F' didn't use ballast resistors , they used a special calibrated resistance wire between the ignition switch and the bypass circuit connection on the starter solenoid .
    So , a ballast resistor isn't needed .
    Clear as mud now ? .
    Me , I converted my '69 C/10 to HEI and used the calibrated resistance wire to kick a cube relay next to the starter , that sends direct 12 volts from the + battery cable to the HEI system and makes for MUCH better running , faster starts hot or cold etc. , blah blah blah yakkity woof and so on .
    Hopefully this now makes some sort of sense ? .
  6. Bill Hanlon
    When all else fails, look in the trash for the directions. According to Accel's documentation for Super Coil "For points applications, a 0.85 ohm ballast resistor is included". For best performance you'd need to remove any existing ballast resistor or resistance wire and install the supplied ballast resistor.
  7. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Thanks for your help Nate and Bill.
  8. 2rods
    2rods Member
    Darwin NT
    Looks like I better try find one...as I don't want to go down the electronic dizzy path if I can help it... Thanks guys
