51 3100 4spd- Remove shifter
Discussion in '1947-1954' started by Haasman, May 9, 2014.
  1. Haasman
    Haasman Member
    N. CA, south of SF
    Can someone instruct me on how to remove the shift from the transmission cover?
    I can obviously get the cover off but uncertain how to remove the floor shifter. (I want to clean off the chipped paint)
    Haasman
    You press down on the ring at the bottom of the shift lever a bit, then turn counter clock wise.
  3. morabuffalo
    morabuffalo Member
    Albuquerque, NM
    shifter tricker
    That little thing can get tricky...I take some vice grips and set them to just inside the thin cap square...I press down a couple of time to break any locks on it...sometimes just stand on it. Then, with both hands pressing down turn counter clockwise about half an inch...
    They at times are a pain and then suddenly while just thinking about it...it pops out with ease.
    Good luck...while off, be sure to cover with a rag or plastic and rubber band.
    rod
  4. Bill Hanlon
    Rod: I use channel lock pliers the same way for the job, I just couldn't explain how. You did much better than I did.
  5. Haasman
    Haasman Member
    N. CA, south of SF
    Thank you gentlemen- I'm gonna go over and try these in a few. I'll report back.
    Haasman
  6. Haasman
    Haasman Member
    N. CA, south of SF
    I used channel locks and just as described worked great.
    Found the the retaining color needed to be push down a couple of times before twisting it off.
    Having a replacement from our host was helpful in understanding how it was held in place and how much of a turn was needed to release.
    Haasman
  7. morabuffalo
    morabuffalo Member
    Albuquerque, NM
    Just did it!
    The reason I sound all so smart is only because I just did the pins...oh, check the pins, I had 6 inches of play to one side...now two inches total...I redid the pins.
    replacement??? I called all over trying to find replacement parts for the shifter....you found some?
    What did you find? What are the stock numbers? They told me I needed to buy a whole new/used transmission.
    rod
  8. Haasman
    Haasman Member
    N. CA, south of SF
    The only replacement part I've found for the floor shifter was the cap, the one we've been talking about. Our site host has them.
    ..... of course buy a whole trans when all you need are $10 of parts. wow ...
  9. Bill Hanlon
  10. Haasman
    Haasman Member
    N. CA, south of SF
    Bill- Great resource! Thanks for this.
    Haasman
  11. vwnate1
    SM420 Parts
    The sad thing is : this robust tranny often gets tossed in the scrap pile at junkyards because they're so damn greedy .
    A while back I was in a yard that had 30 + of these fine transmissions stacked up $500 each , yeah right .
    Behind the office was one good one disassembled in a dirty pool of oil and dirt , it was in amazingly good shape , not sure why they took it apart but they refused to sell even one part off it , instead it sat there for a year or two , got all rusty then went in the scrap pile like the rest .
    Shame on you greedy assholes :mad: .
