Replacement accelerator pedal question
Discussion in '1960-1966' started by Ratnest, May 31, 2014.
  1. Ratnest
    Ratnest Member
    My 66 C10 will be road-ready in a couple weeks. I'm keeping the original gas pedal linkage. After doing the carpet and floor insulation, my new plastic gas pedal won't stay on the floorboard pegs. Changing the height of the pegs didn't work and I broke the darn plastic pedal. I'd like to replace that pedal with something that's cheap, durable, and works well. Maybe one I can bolt to the floor and still use the original rod that comes thru the firewall.
    Anyone have an easy fix idea I might try. Lokar stuff is too pricy for me. Junk-yarding or metal fabbing is OK by me.
  2. Lakeroadster
    Lakeroadster Member
    Central Colorado
    A pal of mine used a '71 C10 pedal. I've looked for his thread and haven't been able to find it :confused:, but I'll keep looking!
    And here it is.. gotta love google searches Mark's 1971-72 C10 Cable Throttle Install
  3. Ratnest
    Ratnest Member
    Thanks my friend. Again, you've given me a good direction to proceed. I'll head to the local vintage junk yard in a couple days and get all the components.
    Initially, I'll try to retain my current carb linkage (threaded rod) and stock firewall pivot fitting. If that doesn't pan-out, I'll go with the cable.:)
  4. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Glad to help.. keep us in the loop and let us know how it turns out for you!
  5. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Stumbled across this today..
    Here's the thread, the quote is from post 158: http://c10forum.com/forum/showthread.php?t=15162&page=4
  6. Ratnest
    Ratnest Member
    Thanks for the reply. That's a classy setup. I'm reluctant to admit what I did to fix my problem. Oh what the heck: My pedal was new and only one of the sockets that fit on the floor pegs was broken. I used my dremel and cut off the bottom of the pedal with the socket holes. Using a Stanley hinge, 2 bolts to replace the floor pegs, 2 self-tappers and some JB Weld....followed by a little adjustment of the linkage. It works fine and is barely noticeable. Total cost $2.50:D
  7. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Nothin' wrong with that. I call my truck the "good enough" truck.. I have a bunch of fixes just like that on it.
    Thanks for sharing, it's all good.
  8. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    Cool RN, I`d never thought of that as a fix...:cool:
  9. Ratnest
    Ratnest Member
    Consider yourself lucky...sometimes the Redneck side of my brain takes over.:eek:
