Brake Pedal Bumper?
Discussion in '1947-1954' started by Coach529, Jun 30, 2014.
  1. Coach529
    Coach529 Member
    Jamestown, ND
    My memory sucks some days. Seems to me I remember a rubber bumper on the brake pedal for when it comes up to hit the firewall.
    Am I dreaming this up? I cannot find it in any catalogs.
  2. Bilbo
    Bilbo Member
    Magnolia, Texas
    Coach, The clutch pedal has a bumper, but the brake pedal travel is determined by the linkage setup to the master cylinder.
    Actually no ~
    The pedal's rubber bumper sets the pedal height against the Toe Board , then the clevis pin is used to properly adjust the M/C's free play , should be no more than 1/4" .
  4. Bilbo
    Bilbo Member
    Magnolia, Texas
    Nate, are you referring to the rectangular rubber bumper, as indicated in the picture I posted? The factory assembly manual I have indicates that bumper is installed on the clutch pedal arm. (Sect 6, Sheet 4), and the Brake Pedal Instruction has no indication of a bumper. (Sect 5, Sheet 2.01) My truck is set up this way. Did I miss something? I know You're the head Guru on these trucks, and I'd hate to think You may be mistaken! :D
    Pedal Bumpers
    I'm always wrong , not to worry .
    Nevertheless , it's very important to have the pedals with the rubber bumpers touch the back side of the toe board firmly from the return spring pull , then you can properly adjust the master cylinder clevis rod .
  6. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Please don't confuse me again!
    Okay who's more correct! Mine is LIke Bilbo's and I can't find any reference to a brake bumper either. The adjustment procedure for the brake pedal makes no mention of it just the firewall clearance. So what do we do? Go to a museum and look at an original factory setup? Woe is me... please end my confusion with a best way to go on this one. I thought I had it done already!:(
    Brake Pedal Adjustment
    Go back and read post # 5 ~
    Attach a good brake pedal return spring so the pedal returns up and hits the toe board with a " THUMP " then adjust the master cylinder push rod so you have 1/4" maximum free travel when depressed by your fingers , before you feel it begin to push the master cylinder .
    This is dead simple , forget about the rubber bumper , adjust it then go drive and enjoy your old truck .
  8. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    I got it!
    Okay on the THUMP and ADJUST. First I'll bleed the brakes again and then do the adjustments. So now I'm no longer confused:)
