Removal of Hood Center trim spear/ 53 chevy pickup
Discussion in '1947-1954' started by mockoski, Jul 16, 2014.
  1. mockoski
    mockoski Member
    Okay here is a silly question,
    Any ideas on how to safely remove and replace the molding that runs down the center of the hood?
    Mine needs to be replaced, but before I dive into it, I was wondering how easy it was to remove. Any suggestions?
    James
  2. Bilbo
    Bilbo Member
    Magnolia, Texas
    On the underside of hood you will see a number of small tabs coming through from the trim strip. Straighten those with a pair of pliers and you can lift off the hood center trim strip. Welcome to the forum. Bill
  3. ol' chebby
    If it has been painted over while on the truck, you may want to run a shrp razor blade between it and the hood to avoid lifting the paint off of the hood.
  4. mockoski
    mockoski Member
    Excellent! Thanks guys.
    James
  5. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Hoiod Center Strip
    If I recall you first need to remove the front chevrolet hood emblem because the strip is trapped behind it.= then do like the other guys said. Just don't over bend the tabs when straightening them as they will break off (Don't ask me how I know). ;)
    Hood Strip
    James :
    # 1 : there are NO SILLY QUESTIONS ! .
    Silly is when you fail to ask then break a hard to find part .
    Use " Duck Bill " pliers when working with sheet metal and clips like this , they'll suffer less damage and be easier for you to work with .
