Gauge cluster removal
Discussion in '1967-1972' started by Shane_68C10, Sep 13, 2005.
  1. Shane_68C10
    Shane_68C10 Member
    Osawatomie USA
    I need some help removing the gauge cluster in a 72 chevy, i get it like halfway out and iy starts to hit on the stering column and the dash. any suggestions appreciated.
    Shane
  2. dvalentine
    dvalentine Charter Member
    Sacramento
    Did you remove the speedo cable ?
  3. Shane_68C10
    Shane_68C10 Member
    Osawatomie USA
    yes, and all the gauges are disconnected im thinking that you can drop the steering column down. any suggesions
  4. dvalentine
    Sacramento
    Yes, you can. Two bolts on the column support. You might be able to just loosen them enough to get the clearance.
    DVal
  5. blue
    blue Member
    buna TX,USA
    sometimes you have to twist it over the colum
