Location of Brake Light Switch on Firewall
Discussion in '1947-1954' started by Haasman, Aug 30, 2014.
  1. Haasman
    Haasman Member
    N. CA, south of SF
    Can someone post the location of brake Light Switch on Firewall?
    In the body work, the holes seemed to have been covered ....
    Thanks in advance
    Haasman
  2. gary1of2
    gary1of2 Member
    Valley Springs, CA
    Where south of Sf do you live? I live in Valley Springs , CA. If you want we could meet and measure where the go. I would bring the the truck to you but my transmission is stuck in second. Let me know.I could take pictures if you would like too.
  3. Guest5979
    Guest5979 Guest
    break switch
    there are 2 small holes under steering colum hole i will try to post pic of fire wall before i filled all the holes
  4. Kens 50 PU
    Pic of LaTroca52's firewall
    Here's a shot of Robert's firewall. Note the 2 holes just below and to the right of the brake pedal hole. That's where the switch is mounted.
    Hope that helps.
    Ken
  5. Guest5979
    Guest5979 Guest
    thanks Ken
    Thanks ken I've been having trouble uploading pics
  6. Haasman
    Haasman Member
    N. CA, south of SF
    Thanks to all.... Nothing better than a picture. This is what I will be doing today :)
    gary1of2- very generous of you. I live in a very small town out by the coast north of Santa Cruz.
    Again, thank you.
  7. Haasman
    Haasman Member
    N. CA, south of SF
    If anyone has a switch installed photo that could share, would appreciate it.
  8. Kens 50 PU
    Either one of these pics help?
    Ken
  9. Tubby
    Tubby Member
    Ignore the rubber bumper on the brake arm in the last pic.
  10. Haasman
    Haasman Member
    N. CA, south of SF
    Thank you, exactly what I was looking for. Located the area where it is to be installed but just didn't seem to make sense.
    Kind of amazed the bottom of the brake light switch is correct when aimed upwards where water could get in to it. But it is probably sealed?
    You mentioned to ignore the brake pedal rubber bumper in the last picture. Are you planning to use it but simply relocate it?
    Thanks for all the replies. The group has been so helpful and essential to my project. Wow ... Happy Labor Day to all.
    Haasman
  11. Tubby
    Tubby Member
    The brake arm did not have a bumper originally
    I mistakenly put one on.
    Decided to leave it since I have no issues with it.
