Is this an alternator or generator
Discussion in '1947-1954' started by bobs51, Sep 2, 2014.
  1. bobs51
    bobs51 Member
    Sacramento, CA
    Sorry for the bad picture and what might be a stupid question. The truck last ran in 2000 and was converted to 12v, I'm assuming that it's an alternator but not sure how to test. One of the previous owners did the 12v conversion and there are a lot of unterminated wires, under the dash is a mess. There is also a resistor on the firewall if that makes a difference. I'm pretty sure the dash doesn't work.
    thanks,
    bob
  2. gary1of2
    gary1of2 Member
    Valley Springs, CA
    looks like a generator
  3. bobs51
    bobs51 Member
    Sacramento, CA
    How to tell if it's a 6 or 12 volt?
    Thanks Gary, I guess I'll try to unbolt it and see if it turns. Is there a way to tell if it's a 12 or 6 volt generator?
    Truck Status - hasn't run in 14 years and ran pretty bad back then.
    Brakes are done and I have a firm pedal.
    Electrical next,
    Then rebuild carb and check fuel
    Then drop the oil pan and see what's there.
    then try to start, shouldn't be too long. I've been ordering parts from the host and starting to enjoy working with my hands again.
  4. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Gen or Alt?
    Any tags on that thing? Red Delco tag is 12v and Black is 6 volt if I recall.
  5. bobs51
    bobs51 Member
    Sacramento, CA
    I'll be pulling it off tonight/tomorrow and let you know. Thanks for the feeback.
