Wanted 47-54 Front Axle
Discussion in 'Truck Parts Wanted' started by cheroking, Nov 15, 2013.
  1. cheroking
    cheroking Member
    Looking for a good Front Axle with tight king pin bosses. can be stripped or complete with king pins. Willing to travel a pretty good way or pay for shipping to 35474
    Thanks Ben
  2. 1951chevy1ton
    1951chevy1ton Member
    Near Sleepy Eye MN
    Which model truck are you needing axle for?, 3100. 3600 and 3800 each use different parts. Where are you located? There are many of us with parts scattered across the USA and Canada and it makes more sense to find one as close to home as possible. I have a wide assortment of used parts for 3800 one ton trucks and I know of a small lot with 3600 and maybe even 3100 trucks. Jerry
  3. Gerry Lee
    Gerry Lee Member
    Hi 1951chevy1ton, I am restoring a 51 5window 1ton and need the aprons between the cab and the bed. They are about 40ins long, Also could use a tail gate. Thank you, Gerry Lee
  4. 1951chevy1ton
    Near Sleepy Eye MN
    Aprons between cab and bed?
    I just do not understand what you are referring to.
    Tail gates I do not have. Thanks, Jerry
  5. Gerry Lee
    Gerry Lee Member
    The apron is the filler piece between the back of the cab and rear fender above the running board.
  6. 1951chevy1ton
    Near Sleepy Eye MN
    Apron
    I have one side, not the other. I think I have the driver side. Too dammed cold to go out there now.
  7. Gerry Lee
    Gerry Lee Member
    1951chevy1ton
    To cold and snowy here to. No hurry for the apron it con wait till spring. Let me know what your thing for a price. Is your 1ton a 9' stepside dump by chance? If so can you read the information on the id. plate? I need the information off of it if you have it. Thank you Gerry
  8. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Axle
    CHEROKING, Did you get an axle? What type truck 1/2 ton 3100? :confused:
