oil filter removal??
Discussion in '1947-1954' started by denisf, Sep 8, 2014.
  1. denisf
    denisf Member
    Colchester, CT/ Clermont, FL
    Ok must be missing something. Canister rotates but when I lift it it moves 1/4 inch and feels like a mechanical stop. Ideas? What am I missing. Thanks, Denis
  2. 2OR4Wheels
    2OR4Wheels Member
    Sierra Vista, AZ
    I just took mine out. was vacuum locked (think when you pull the drawstrings on a kitchen garbage bag, then try to pull it out of the can). Disconnect the bottom line, or pull the little drain plug in the bottom. Then it should come out.
  3. Chiro
    Never had an issue. Should pull out with a little bit of force
  4. denisf
    denisf Member
    filter is out
    got it out with more force then I would expect. Denis
