65 Fleet side Parting out
Discussion in 'Truck Parts for Sale' started by MurrietaMike, Sep 4, 2014.
  1. MurrietaMike
    MurrietaMike Member
    Wildomar, Ca
    I am in the process of purchasing a 65 fleet side doner.... I don't need much so I will be parting this out..... What do you need?
  2. MurrietaMike
    MurrietaMike Member
    Wildomar, Ca
    Looks like I will have this doner by Wednesday....
  3. Guest5979
    Guest5979 Guest
    frontend
    Will the front cross memember and arms fit in a 52 chevy truck and are the wheels 5 lug or 6 lug?
  4. Guest5979
    Guest5979 Guest
    parts
    What parts are you getting rid of forgot to ask?
  5. MurrietaMike
    MurrietaMike Member
    Wildomar, Ca
    I am not sure if the parts will fit..... it's a c20 so 8 lug.... I will have a better idea next week as to what is there.... I dont think I need the front suspension.... I know I dont need the bed or the cab and frame..... probably dont need front inner and outer fenders..... if you need something specific just ask...
  6. MurrietaMike
    MurrietaMike Member
    Wildomar, Ca
    I will have a 5 lug rear end up for grabs in the near future as well
  7. Guest5979
    Guest5979 Guest
    parts
    Left you my number on a pm my neighbor might interested in the cab and other parts give me a call thanks
    ROBERT
  8. MurrietaMike
    MurrietaMike Member
    Wildomar, Ca
    It was good talking to you.. I will let you know when I have possession of the truck.
  9. MurrietaMike
    MurrietaMike Member
    Wildomar, Ca
    So the doner truck is in my yard. I should start dismantling it this weekend. Will take more pictures at that time. Let me know what you need...
  10. LostMy65
    LostMy65 Member
    Hey, are you Mike Murrieta from Woodland CA? :)
  11. MurrietaMike
    MurrietaMike Member
    Wildomar, Ca
    Nope.... not me....
  12. Gregsh
    Gregsh Member
    Madison, ms
    Mike, do you have the parking brake handle and parts that are mounted under the steering column? I could use those parts if you have them. Thanks!
  13. MurrietaMike
    MurrietaMike Member
    Wildomar, Ca
    Yes... which parts do you need....
  14. Gregsh
    Gregsh Member
    Madison, ms
    Just the handle and brackets under the steering column. All my cables are there but PO removed the actual handle assembly from the steering column. Thanks.
  15. MurrietaMike
    MurrietaMike Member
    Wildomar, Ca
    Sent you a PM
  16. Gregsh
    Gregsh Member
    Madison, ms
    Left you a message on your member page. Thanks!
  17. MurrietaMike
    MurrietaMike Member
    Wildomar, Ca
    Saw the message yesterday and saw you left your number but for some reason the message is gone today. Please resend your number.
    Also,
    Someone else left me a message about parts but it is gone as well. Please resend.
  18. MurrietaMike
    MurrietaMike Member
    Wildomar, Ca
    Truck is completely dismantled. Looks like it was a camper special meaning there is an adjustable dock bumper and helper type springs on the trailing arms.....
  19. Pimpston65
    Pimpston65 Member
    any parts left? like the booster mounting plate and screws, does it have A/C? hows the dash? does it have a brake pedal with "powerbrake" on it? any other little dash parts or ac parts available? oh is it auto or manual?
  20. MurrietaMike
    MurrietaMike Member
    Wildomar, Ca
    It was one with power brakes. the booster was gone before I got to it but the mounting plate and pedal are there. The cab is gone with the dash but I may have access to a 64 cab. still working that out. The AC is all going into mine but there may be some dash parts depending on what you need. It was a manual with three on the tree.
