Oil on the left rear rim
Discussion in '1947-1954' started by wokri, Oct 14, 2014.
  1. wokri
    wokri Member
    Germany
    Hello,
    i saw the there was oil in the rim of the left rear wheel. Where can come? What can be the mailfunction?:eek:
    Ask
    Wolfgang
  2. ol' chebby
    Check axle seal or brake cylinder,
  3. wokri
    wokri Member
    Germany
    Hello, ol' chebby,
    I will do. :D
  4. coilover
    If it's oil then most likely an axle seal. I'm sure you have a shop manual that shows axle removal. You have to pull the rear cover, the spider gears locking pin, the spider gears shaft, and then push in on the axle till a "C" clip on the inner end of the axle will come off. The axle will then pull out. You will have to rotate the carrier assembly till there is room to remove the shaft and if possible don't move from this position as this will keep the spiders aligned so the shaft slides right back in.
