My christmas present to myself
Discussion in '1947-1954' started by mobileortho, Dec 29, 2014.
  1. mobileortho
    mobileortho Member
    Hampton, VA
    Well, the video I promised of a nice smoky burnout never happened. The supposed "rebuilt engine" was a bust. :mad: The studs on the heads were not installed properly so the lifters couldn't adjusted properly & one of the cylinders was washed. Turns out the shop that built it is closed and if this is an indication of the quality of their work I see why. Now this could have been an easy fix, but I decided to cut my losses & just go with a crate engine. Got this 350 from Jegs today & if you're keeping count, yes this is engine #4 but hopefully the last because this one comes with a 3 year 100,000 mile warranty. We'll see how this goes....
  2. ccharr
    Sorry to hear you were having these issues but glad to see you are moving forward with this new crate engine. Best to you.
    OOOOoooohhhhhhhhhh............
    As much as I'm a Die Hard InLiner , seeing a brandy new engine in the Factory Crate , is a glorious thing ! .
    You're going to love this .
    Consider Ram's Horn exhaust manifolds, they look great and work well too , available brandy new cheaply .
    I'm cleaning up an engine for my truck then next year when I retire I plan to overhaul all the old engines I have littering my back yard , see if anyone wants good running Vintage InLine engines .
    Prolly not but I'll have a good time building and breaking them in... :D .
  4. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Robert, what's the spec's. on the Jeg's motor.. or maybe the Jeg's P/N?
    Thanks,
    John
  5. ol' chebby
    Best way to do it. I now plan to only install crates. rebuilds are causing too much trouble.
  6. mobileortho
    mobileortho Member
    Hampton, VA
    John the part # is 809-10067353, the cost was $1509 & includes shipping. I copied & pasted the specs. below:
    This universal 350ci engine uses a brand new block and can be used as a replacement for most GM vehicles from 1973-85. It produces 260 HP and 350 ft/lbs torque with a 4-bbl carb and headers. It can be used as a replacement or as a retrofit into almost any vehicle. This new 350 crate engine comes with a GM warranty and is covered for 3 years or 100,000 miles in applicable GM vehicles only. JEGS has the GM Goodwrench Chevy 350 for sale at a great price!
    Specifications ?4-bolt main with 2-piece rear main seal
    ?Cast iron crankshaft
    ?LT1/LT4 powdered metal connecting rods
    ?Cast pistons (dished)
    ?Hydraulic flat tappet cam (.383''/.401'' Lift, 194 / 202 Duration @ .050'', and 112? lobe separation)
    ?Cast iron cylinder heads with 76cc chambers
    ?8.5:1 compression ratio
    ?Block is compatible with left or right side oil dipstick (Requires Plug for Unused Side - Sold Separately Below)
    ?4-quart oil pan
    ?Timing tabs for a 6-3/4'' or an 8'' balancer
    ?Recommended spark plug: Accel #111-0574S-4 or any spark plug with 14mm .460'' reach, 5/8'' hex, tapered seat, projected tip
    ?Requires:809-19299222
    ?Not Intended for Marine Use.
  7. mobileortho
    mobileortho Member
    Hampton, VA
    Nate, I had actually considered Ram Horns but decided to reuse the block huggers.
  8. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Crate vs. Rebuild
    Thanks for posting the spec's. Charles.
    I don't think a fella could get a SBC rebuilt today for $1,500? I paid $1,400 in 1996 to get the SBC for my Model A rebuilt by my engine buildin' buddy Charlie.
    The only part that sticks in my craw about the GM crate motors is the "Hecho En Mexico" part. I look at everything I buy.... and my wife gives me "that look" and tells me to "get over it". ;)
    John
  9. Zig
    Merry Christmas indeed!!!
    Outstanding gift idea, Robert! With that in there you could cruise all the way out here for some BBQ and adult beverage or two! :D
  10. Zig
    I had a dream...
    that I had started up my 228. It sounded incredibly awesome. As I sat there listening to it, I remembered I had never installed the water pump! I quickly killed the engine, ran around and popped the hood. I was even more shocked to see that someone had removed the head! Oil and antifreeze all over my nice, new paint job! :eek:
    Hey, it *did* sound nice, however. There is obviously a lot to be said for these old 6 bangers. Tough little engines!
  11. 50 Chevy LS3
    50 Chevy LS3 Member
    Indiana
    Can't get a machine shop to do much for $1500.
    I was told recently $1700 labor only to build a 383 out of a 350 four bolt engine I already have. Total bill would be around $6000. Target HP would be 450.
    I'm finding out LS3, L99, and L92s are really climbing in price in salvage yards. They are so close to GM crate prices that it's almost a no-brainer to buy new! Crazy junk-men...
  12. RidesWithYah
    RidesWithYah Member
    Lexington KY
    Am I the only one wondering how many SBC V8s your truck has to reject before you figure out it wants an Inline Six?
    :D
  13. mobileortho
    mobileortho Member
    Hampton, VA
    HA! I had a six in it when I got it and the initial plan was to keep it until it too crapped out on me!
  14. Bill Hanlon
    Zig
    Zig:
    Send me an e-mail address and I'll send you 228.MP3, an audio recording of my 228. You can sit in your truck and play it back.
    - Bill
  15. mobileortho
    mobileortho Member
    Hampton, VA
    Decided to give fuel injection one more try.
  16. fasteddie1017
    fasteddie1017 Member
    Pearland,Texas
    Bought the exact same engine from Summit in October. Best value out there and perfect engine for my 53
  17. mobileortho
    mobileortho Member
    Hampton, VA
    Jegs has a Blueprint 383ci/ 430HP/ 450TQ with a 30 month 50,000 mile warranty for $3695. part #138-BP38313CT1
  18. Zig
    DAAAaaaaannng that looks sexy!!!
    Why not, right? Good luck and I got my fingers crossed for you that it will work the way it's supposed to this time!
  19. Zig
    Thanks, Bill!
    Bill~ Could you fire that baby up and drive it past Ken's house? That way it's just not idling away and it will allow me the opportunity to run my truck through the gears while I'm listening. THANKS! ;)
  20. vwnate1
    Engine Choices
    Sigh .
    Evan is right of course .
    For me , not only does it have to be an InLiner , it also has to be built by me personally .
    Talk about bleeding hemorrhoids , wasted time and Dollars .
    Eventually it'll run the way I want it to so it's all good in the end .
    I hate to say it but crate engines with Fuel Injection prolly make the most sense and are easiest to do .
    Take that Hecho In Mexico Crate Engine and spray paint it CHEVROLET ORANGE , dress it how you like and you should be very happy .
