  1. ol' chebby
    Swap in a 700r. Lower 1st gear and 70% OD!
    Fredericksburg TX
    Mike: You need to fix your electrical system. Speedo shows almost 80 MPH but ammeter shows a discharge! Ought to be charging big time at that speed.;)
  3. Coach529
    Coach529 Member
    Jamestown, ND
    Are the dimensions the same? Would hate to have to modify my brand new driveshaft!!
  4. Coach529
    Coach529 Member
    Jamestown, ND
    I need to rewire that gauge some day.......... :rolleyes:
  5. ol' chebby
    If it is a long tailshaft 350 the dimensions are exact.....even the trans mount is in the same location. If you have a short output shaft 350, the 700 is a few inches longer. The swap is still well worth having the driveshaft shortened. My shop will do it for 1 hr labor...about $60. I can get one cut to size with new u joints for $100.
  6. Coach529
    Coach529 Member
    Jamestown, ND
    Walked right past my company truck and hoped in Henry for my 15 mile commute to work. :metal:
    Henry's step brother "Gene" was here too!!
    Gene is a baddass '49 GMC owned by a coworker. Sweet build done about the same time as Henry!!
    383 stroker, tubed with narrowed 9", over the frame headers..........dream build list!!
    Cool thing is "Gene" is also a Family truck It was Casey's Grampa's truck.
    Both trucks live 4 blocks apart!!
  7. Bill Hanlon
    Fredericksburg TX
    Gene's drag chute needs to be attached to something more substantial than sheet metal.:)
  8. Coach529
    Coach529 Member
    Jamestown, ND
    I tend to agree......:cool:
  9. Guest5979
    Guest5979 Guest
    burn outs
    No youtube video of the smokie burn outs?
    I hear corkey coker calling for your order of fresh wide white to replace the soon to be bald ones:D:D:D:D
  10. Coach529
    Coach529 Member
    Jamestown, ND
    No videos yet.......next time!!
  11. Coach529
    Coach529 Member
    Jamestown, ND
    Nothing new to post.
    Got the timing dialed. Somehow it was very retarded. Set perfect now. Runs even better now. Carb is dialed in as well.
    Lost of little stuff to do, but I am enjoying driving it to much. If I go more than a couple days without at least a short cruise I get crabby!!
  12. Coach529
    Coach529 Member
    Jamestown, ND
    Slowly tinkering as I have time.............there is never enough time.
    Cam, sprockets and chain are here.
    I started "Finally" putting in my passenger side Altman EZ latch kit. It is sad I put the drivers side in almost 2 years ago.
    My 12 circuit EZ wiring harness came in as well!!
  13. The Hill Boys
    The Hill Boys Member
    Gilbert, AZ
    Which wiring kit is that?
  14. spurgeon
    spurgeon Member
  15. The Hill Boys
    Gilbert, AZ
  16. spurgeon
    spurgeon Member
    I figured that. Just amusing myself.
  17. vwnate1
    Progress !
    No worries Coach ;
    You're getting there bit by bit .
  18. Coach529
    Coach529 Member
    Jamestown, ND
    Finally got started on the wiring. First things I did was gut all the old wiring out!! It did not take too long.
    After that I laid the new wiring and removed circuits and wires I would not be using. I installed the fuse block under the dash and starting pulling wires to the appropriate areas.
    After the wires were in the area's I tackled the dash. It is always nice to get the toughest stuff out the of the way first.
  19. ol' chebby
    Hey, nice tach....
  20. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Awesome photo Coach.....
